Side mirrors(Fixable)
4 replies to this topic
#1 88john63
88john63
    Newbie
  • Pip
  • 7 posts
  • Ford Model: Fiesta '97 1.3 Endura, Encore
Posted 01 November 2008 - 09:25 PM
Hiello 2 1+all,
Well,i just registered 5 minutes ago and i already asking for help, :rolleyes: ,anyhow, my new(new to me anyway) fiesta, the wing mirrows on both sides dont move when i toggle the little joystick thing inside, i have tried gently to push it, pull it twist and all that, I have the mirrors in place now, but would prefer to be able to fix them, i chekced out prices for new ones and would prefer not to spend that at this side of xmas thanks very much, or anytime at that matter,from the outside they look fine, the mirror glass itself ain't loose at all, i have found nothing on the net about this exact subject, its mainly about replacing the whole thing or replacing hte glass, which i dont need, I was hoping to find the time today to take on out and see if i can see the problem but a got caight up bringing my ma shopping and then daylight was gone.
basically, if anyone has ever had the same type of problem, or any ideas, or can even point me in the direction of a website that covers this sorta thing i would be greatly appreciative,
thanks fo taking the time to read this(thats if you didn't get bored and give up halfway :lol:
#2 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 02 November 2008 - 08:39 AM
see if your local libary has a haynes that you could borrow.
#3 Russ
Russ
  • 293 posts
  • Ford Model: Fiesta 1.4i zetec
Posted 02 November 2008 - 10:36 AM
Sometimes the mirror adjustor is connected to the rear fixing on the mirror in a ball joint, it could be that the ball joint has worked itself loose or the actual adjusting lever, has broken inside the housing. In which case, you'll need a new mirror probably as i can't see anyone selling the 'inner workings'. Maybe try a scrappy for a replacement mirror complete?
#4 chas
chas
  • 30 posts
  • Ford Model: fiesta
Posted 14 November 2008 - 07:33 AM
Hiello 2 1+all,
#5 chas
chas
  • 30 posts
Posted 14 November 2008 - 07:49 AM
Sorry about that, mods new to this. Just wanted to add I had a similar problem and ended up trying my local motor factor that was a reasonable £23 for a wing mirror as opposed to over £60 from Fords. The patern parts seem fine. Gave up with breakers after running about and wrecking a tyre in the process. Hope this helps.
