foxee Posted March 22, 2011 Share Posted March 22, 2011 Hey all.. Have a problem with my 05 focus… When I turn on the indicator to turn left the bulbs on the front and side light but not the rear… I have checked the bulb and connections but all seems ok… the fuses seem good also.. The ticking noise that is made when the indicator is on to the left is fast.. When the right is on the ticking sound is normal.. Hope all of that has made sense… :o Quote Link to comment Share on other sites More sharing options...
btmaldon Posted March 22, 2011 Share Posted March 22, 2011 Have you tried another bulb? It does sound like the bulb, or oxidation on the contacts that would also cause the same problem. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted March 27, 2011 Share Posted March 27, 2011 Have you tried another bulb? It does sound like the bulb, or oxidation on the contacts that would also cause the same problem. fast ticking=new bulb needed the fast ticking is to let you know Quote Link to comment Share on other sites More sharing options...
foxee Posted March 29, 2011 Author Share Posted March 29, 2011 Yea I tried a new bulb,the old one was fine but I changed it anyways, checked the connection at the base of the bulb and the fuses too.. I didnt seem to fix it but then we got a week of good dry weather.. probably 13c, it started working again. The only thing that I could put it down too was that a wire somewhere was damp... Quote Link to comment Share on other sites More sharing options...
jackfitz Posted September 7, 2013 Share Posted September 7, 2013 I am having the same problem with my 06 Ghia where the left side indicator flashing faster on dash and light not working went to Halford they said it was not the bulb or fuse, did anyone find an answer to the problem ? Quote Link to comment Share on other sites More sharing options...
