clubriza Posted March 28, 2011 Share Posted March 28, 2011 Hi, I have a Ford Focus MK1 2ltr T reg which makes a werrring noise from the rear. When Im driving the noise disapears when turning left. I suspect it to be the wheel bearing so I jacked up the rear and checked for movement - None but the n/s was a lot noiser when spinning it. Last year I changed the rear discs, pads & calipers (which also do the handbrake) How easy is it to replace the rear wheel bearings? would i need to use a press? I can get a new wheel bearing for £20.70 from sutton auto factors Thanks Michael Quote Link to comment Share on other sites More sharing options...
stef123 Posted March 28, 2011 Share Posted March 28, 2011 Hi, I have a Ford Focus MK1 2ltr T reg which makes a werrring noise from the rear. When Im driving the noise disapears when turning left. I suspect it to be the wheel bearing so I jacked up the rear and checked for movement - None but the n/s was a lot noiser when spinning it. Last year I changed the rear discs, pads & calipers (which also do the handbrake) How easy is it to replace the rear wheel bearings? would i need to use a press? I can get a new wheel bearing for £20.70 from sutton auto factors Thanks Michael i have done many focus wheel bearings, a press is required for this. ive seen rear focus bearings take 10t to shift them. Quote Link to comment Share on other sites More sharing options...
