Hi all,my wife's ford KA 3 keeps cutting out when slowing down to junctions. It seems to do it as you put the foot down on the clutch and the revs drop,even thou the clutch is well down. It has started to do this more often now and its starting to get very dangrous. Any help would be greatfull........ Many thanks Paul.....
ka 3 cutting out!!
Started by seasider, Nov 14 2008 05:40 PM
3 replies to this topic
#1
Posted 14 November 2008 - 05:40 PM
#2
Posted 14 November 2008 - 05:46 PM
sounds like the idle speed controlle valve playing up its a common problem, try cleaning it with carb cleaner. it could also be the speed sensor starting to break down.
#3
Posted 14 November 2008 - 05:53 PM
you can also try cleaning the temp wire that's connected to the engine at the front of the enginesounds like the idle speed controlle valve playing up its a common problem, try cleaning it with carb cleaner.
it's a simple bayonet fitting that's used.
keep us posted if you get it sorted m8
#4
Posted 14 November 2008 - 05:57 PM
Will do,thanks for the VERY quick responces. Will have a look tomorrow. Thanks again.....you can also try cleaning the temp wire that's connected to the engine at the front of the engine
