Brakes Have Gone Tight After Handbrake Adjustment?
2 replies to this topic
#1 mathewmmr
mathewmmr
  • New Member
  • 35 posts
  • Ford Model: Fiesta Finesse 1.3
Posted 22 April 2011 - 05:15 PM
I just tightened my handbrake quit alot as it was rolling along when i was parked on hills and now my brake pedal is much tighter than it used to be, is this meant to happen or what?
Have something to contribute?
#2 stef123
stef123
  • Management
  • 5,872 posts
  • Name: Stefan
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 22 April 2011 - 11:40 PM
presumably you just tightened the screw? ideally you need the rear wheels off the ground to do this correctly, as over tightening it will mean the pads/shoes are in contact all the time (sounds like your problem)
#3 fishpond 47
fishpond 47
  • 363 posts
  • Ford Model: mk3 mondeo x2 + a ka
Posted 23 April 2011 - 06:40 AM
As said above, did you have the rear wheels off the ground to check that the wheels still spin once you ajusted the cable?,
The reason your pedal feels harder is because you have taken the clearance away that the shoes/pads have to travel before they do anything, so answer to your question is yes the will feel pedal harder, on another note, before you adjusted your handbrake cable did you check the shoes/pads for wear?
Not what you're looking for?
