Why Is My Focus Hunting?
2 replies to this topic
#1 daisylou
daisylou
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Ford Model: focus
Posted 26 April 2011 - 03:47 PM
please help....my 54 plate focus has had 2 coil packs, sparks and leads then eventually 2 valves which finally resolved the problem of it hunting when stationary, now 2 months on engine management light is back on and hunting again!! its previously been on diagnostic machine and had compression check. why has problem returned and what could be the cause? open to suggestions!!
Have something to contribute?
#2 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,543 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 26 April 2011 - 07:45 PM
it could be many things,air leak on vac pipe,iscv playing up(idle speed controlled valve) or a lambarda sensor,get the codes read this should point you in the right direction.
#3 spikeymj
spikeymj
    Member
  • New Member
  • PipPip
  • 13 posts
  • Ford Model: focus ebony
Posted 30 April 2011 - 10:48 PM
just a few thing i had with my brothers car when it was doing the same it took me 3months at looking at the car and then i clocked on what it was
1)have you changed the throttle body on the car
if not
take the air intake hose (the bit from air box to engin)off it and have a look when the car is running see if it is letting air in
if it has been changed it could be the wrong one
just a few things to look at be4 you change anything that costs to much
Not what you're looking for?
