bigbossowen Posted May 2, 2011 Share Posted May 2, 2011 hi all. right im having problems with changing gear from 1st to 2nd im geting a grinding but if i go from 1st then neutral then in to 2nd its fine its bad when its cold and getts better the warmer she gets but some times is there when warm do you think this is the clutch or a synchro-ring. do ford get much problem with there 6 speed box. i now there dmf system is not amazing thanks for your help Quote Link to comment Share on other sites More sharing options...
ian_c41 Posted May 2, 2011 Share Posted May 2, 2011 hi all. right im having problems with changing gear from 1st to 2nd im geting a grinding but if i go from 1st then neutral then in to 2nd its fine its bad when its cold and getts better the warmer she gets but some times is there when warm do you think this is the clutch or a synchro-ring. do ford get much problem with there 6 speed box. i now there dmf system is not amazing thanks for your help i had this problem in the end i couldnt get any gears it turned out the dmf wanted changing Quote Link to comment Share on other sites More sharing options...
bigbossowen Posted May 2, 2011 Author Share Posted May 2, 2011 i did fear that but on the flip side at least i have not got to pay for a gearbox rebuild as well as a whole dmf and clutch.... Quote Link to comment Share on other sites More sharing options...
