So far the car has had the following done:
- New battery
- New oil filter and oil
- Cleaned air filter
- Cleaned throttle body
- New IAC valve
- New spark plugs
But problem still occurs!
To best describe it, the car fails to 'catch' the idle speed when the clutch is dipped during cold running. If the engine is revving at 3000rpm or above and I press the clutch and keep it there, the revs more or less always drop to zero causing the battery light to come on. As the engine continues to run the problem slowly dies down.
I am beginning to suspect the TPS, only becuase I disconnected it while the engine was idling and no change was noticed. Does the operation of the TPS depend on outside temp?
Any advice apprecieted!
