Vss - Speed Sensor
#1
Posted 11 May 2011 - 03:09 PM
#2
Posted 11 May 2011 - 03:33 PM
I need to change the speed sensor on my Fiesta Mk 6, I have a replacement but with no workshop manual can anyone tell me where exactly the VSS is located. I had a cursory look and it wasn't obvious, better still a photo would be great as a `picture paints a thousand words
Haynes Manual £20 all you'll eva need to know
#3
Posted 11 May 2011 - 04:55 PM
#4
Posted 13 May 2011 - 08:26 AM
#5
Posted 13 May 2011 - 09:03 AM
#6
Posted 13 May 2011 - 12:05 PM
#7
Posted 13 May 2011 - 01:04 PM
The VSS is held in place by a pin, once removed it should just pull out.
ABS models work out the speed from the ABS sensors so don't need a VSS.
#8
Posted 13 May 2011 - 01:15 PM
#9
Posted 17 May 2011 - 10:41 PM
Hi Dan ureka, I have found it now I have the age old problem (apparently) of withdrawing the pin. There appears to be a metal plate over the front, does the pin withdarw throught that, if so what is the best method of withdrawal. (said the actress etc)
not always sensor tsb says check resistence between pin 1 and 2. (1=volts feed 2=sig out 3=ground) should be 1.5 kohms ± 5%. sure ford released a pcm update for vss faults, regards steve
#10
Posted 28 January 2013 - 04:27 PM
http://www.fordowner...ro/#entry219799
nigel
