Fusion Tdci
#1
Posted 12 May 2011 - 08:51 PM
write I have just bought a 52 reg 1.4 tdci fusion and basically it seems low on power it will get upto 70 after a while but there is defiantly no turbo action going on and on the way back eac fail flashed up but turned it of and not come back on since also noticed there is no engine management light or glow plug light plugged the car in to computer and came up with egr valve insufficient flow or along them lines have looked at the turbo and looked ok from what I could see bit there is abit of blue smoke which led me to think turbo maybe shot but if anyone has any ideas of what could be stopping the turbo to function pls let me know my mum has fiesta tdci so could swap parts to eliminate if needed thanks in advance
#2
Posted 13 May 2011 - 02:45 PM
#3
Posted 13 May 2011 - 07:13 PM
#4
Posted 16 May 2011 - 09:39 PM
#5
Posted 23 May 2011 - 09:42 AM
#6
Posted 24 May 2011 - 10:09 PM
#7
Posted 27 May 2011 - 09:17 PM
hi there thanks for the reply the problem with the lack of power was the turbo was coked solid nearly on the exhaust side cleaned it out and job done car producing boost and driving as it should however I still have no eml on the dash when ignition is turned on but can confirm the light itself works as fine in test mode so may still be a problem with Ecu/cluster and also when left on idle get some blue smoke come out and have read that sometimes a software update can cure this as it's not fueling correctly. just hope it's not the rings on there way out what does your repair consist of is it a software update on the Ecu aswell as Any possible repairs ?
hi please read here for repar details
http://www.fordowner...showtopic=23038
in short using ford ids (dealer tool) scan all modules/controllers for faults.
monitor vehicle info on computer while on roadtest
if fault eac fail is present or has been present ford will tell you new ecu....
my repair is to remove/open/and repair ecu instead of fitting new
followed by updating ecu software to latest release (march 2011 calibrations)
roadtest vehicle for 20/30 miles including motorway and monitor car on pc again
give you a bill and recieve a thankyou for saving you £850 ish
thanks steve
#8
Posted 16 November 2011 - 06:17 AM
The car, after a lot of effort, reached some speeds.
The Ford service centre diagnosed (or may be not) the problem to be clutch failure.
Another local service centre diagnosed it as TURBO FAILURE.
It was in fact the turbo that had failed.
It was changed, and the car was back to its usual peppy self.
