Key Battery
4 replies to this topic
#1 wilbyforce
wilbyforce
    Member
  • PipPip
  • 13 posts
  • Ford Model: C-Max
Posted 24 November 2008 - 11:01 AM
I've owned my 3 year-old C-Max since April this year. For a good few months the remote key fob has worked fine but in the last 2 months I've gone through 2 fob batteries. When the batteries are good the fob works normally. Does anyone know if they can malfunction and drain batteries abnormally quickly?
Many thanks.
#2 Russ
Russ
  • 293 posts
  • Ford Model: Fiesta 1.4i zetec
Posted 24 November 2008 - 05:25 PM
Many thanks.
Anything electrical using batteries can and sometimes do drain the batteries. I have a set of verniers that should auto switch off, the screen goes black as if theyre switching off but within a day or two the batteries are dead. All i can do is replace the battery so it sounds like you 'may' need a new keyfob unfortunately. I'd check the connections first though in the fob.
#3 wilbyforce
wilbyforce
    Member
  • PipPip
  • 13 posts
  • Ford Model: C-Max
Posted 25 November 2008 - 10:33 AM
Thanks Russ. :)
#4 c-maxxer
c-maxxer
    Member
  • PipPip
  • 14 posts
  • Ford Model: C-Max CVT auto Zetec
Posted 08 December 2008 - 01:57 PM
I had a Puma with basically the same key remote. I accidentally went swimming one day with the key in my pocket. After that the battery went flat in a week or so every time I renewed it.
In my case I took the key to pieces, removed the battery and gave the electrical circuits a thorough clean with switch cleaning spray (Servisol). I wiped the key clean, left it overnight, put it back toether and then refitted the battery. the battery then lasted ages.
Worth a try maybe ?
#5 wilbyforce
wilbyforce
    Member
  • PipPip
  • 13 posts
  • Ford Model: C-Max
Posted 11 December 2008 - 11:48 AM
Worth a try maybe ?
Thanks, I'll keep that in mind. It's about 3 weeks since I put a new Energiser battery in and it seems fine. I'm hoping that I've just learned that (IMO) Tesco own brand batteries are rubbish.
