Clutch Squeak
3 replies to this topic
#1 lublin
lublin
  • 98 posts
  • Ford Model: Escort Estate 1.6 16v . Built 14/11/95.
Posted 18 May 2011 - 11:40 PM
For the first half mile when the clutch is cold it squeaks every time I change up. It make a noise at no other time, neither does the thrust bearing(no rumbles, etc). What could this be, is it a sign that it's on it's way out?
#2 lublin
lublin
  • 98 posts
Posted 14 June 2011 - 09:27 AM
I've since found out that it's something to do with engine movement as when I throttle on and off again in a low gear it makes the squeaking sounds. It must be exhaust related as it gets a lot quieter or completely stops after a short time when it's warmed a bit. The seal and springs on the exhaust less than a year old.
Maybe some spacers on the springs is required?
#3 vinnyvangough
vinnyvangough
  • Super Mod
  • 2,225 posts
  • Name: Steve
  • Ford Model: Ford Escort RS2000 Mk6 & Mk2 Escort
  • Year: 1996
Posted 14 June 2011 - 04:54 PM
First thing i would check is all engine and gearbox mounts.
Then check all other bolts etc
#4 lublin
lublin
  • 98 posts
Posted 15 June 2011 - 11:15 AM
Thanks for the reply. I had a quick look at the engine mountings and they all seemed tight but I'll have a closer look in a day or two.
