6 replies to this topic
#1 Reece
Reece
    Newbie
  • New Member
  • Pip
  • 5 posts
  • Ford Model: Fiesta mk6
Posted 19 May 2011 - 11:32 AM
Hi there I currently have a 1.25 fiesta finesse (zetec s look) and I want to put the 1.6 lump in now as I have completed the look just need the engine, I know it is just a straight swap and I can use the same gearbox but what about all the other bits? E.g alternator, pullys, radiator and so on, basically everything apart from the lump it's self, will I be able to use all the same stuff or will I need zetec s parts?
Thanks Reece
Have something to contribute?
#2 vinnyvangough
vinnyvangough
  • 2,325 posts
  • Name: Steve
  • Ford Model: 2003 Focus TDCi, Escort Mk6 RS2000, Mk2
  • Year: 2003
Posted 19 May 2011 - 03:57 PM
I'm not too sure on this conversion, but i have a feeling you may need some of the zetec S parts.
I hope you realise you will most probably need the engine wiring loom and the ECU as well as the PATS system that belongs to the ECU
#3 Reece
Reece
    Newbie
  • New Member
  • Pip
  • 5 posts
Posted 20 May 2011 - 08:45 AM
Won't I be able to use the same loom and just get it remapped? Or will I need all different electrics and brain?
Thanks Reece
#4 vinnyvangough
vinnyvangough
  • 2,325 posts
  • Name: Steve
  • Year: 2003
Posted 20 May 2011 - 11:55 AM
I dont think so.
Its the same with the Escort, if you want to go from the 1.6 to the 1.8 or 2.0. You can use the original ECU but it dont run right and is flat, plug in the correct ECU and your away.
#5 Reece
Reece
    Newbie
  • New Member
  • Pip
  • 5 posts
Posted 20 May 2011 - 01:25 PM
Ah ok mate have to get that then, not sure about the rest of the boys though been looking but can't find anything that says about changing any of the other parts, does any1 known if I have to change any of the little bits like alternator radiator etc
Thanks reece
#6 vinnyvangough
vinnyvangough
  • 2,325 posts
  • Name: Steve
  • Year: 2003
Posted 20 May 2011 - 01:28 PM
Best thing to do is get a MOT failure and have the whole car as a donor, swap everything you need over, then scrap the shell for some money back
#7 Reece
Reece
    Newbie
  • New Member
  • Pip
  • 5 posts
Posted 20 May 2011 - 01:42 PM
That's the thing that will be expensive to get a donor car that's my shape, its cheaper with the old shape but it ain't a straight swap then because the mounts are different, really need to know if it will use my component or not or I will get a the whole lot instead of just the block
Thanks reece
Not what you're looking for?
