weather getting in
Started by cks, Nov 24 2008 10:57 PM
4 replies to this topic
#1
Posted 24 November 2008 - 10:57 PM
as the snow melts on windscreen i believe its finding its way under scuttle panel lower passenger side and down into footwell. Common fault ?
#2
Posted 25 November 2008 - 03:55 PM
check the seal for the pollon filter housing, its the most common cause of passenger footwell leakage.
#3
Posted 25 November 2008 - 06:13 PM
thanks will check this outas the snow melts on windscreen i believe its finding its way under scuttle panel lower passenger side and down into footwell. Common fault ?
#4
Posted 25 November 2008 - 07:46 PM
Check under the windscreen,( under the bonnet ) there may be an area the dead leaves are settling and rotting in the wet, this causes the drain holes in the bulkhead to get blocked and the water ends up coming into the cabin! I had similar on a cavalier and now i have a ford i can see the dead leaves inside an area under the windscreen but i cant get to them to remove them so expect at some point to be paddling!
#5
Posted 27 November 2008 - 10:56 PM
pollen filter housing was slightly lifted,sealed with gaffa tape for quick fix,no more leaks, for now!THANKSas the snow melts on windscreen i believe its finding its way under scuttle panel lower passenger side and down into footwell. Common fault ?
