Uneven Idle
11 replies to this topic
#1 MARLEY
MARLEY
  • New Member
  • 75 posts
  • Name: PAUL
  • Ford Model: MK2 FOCUS 2.0 TDCI GHIA
  • Year: 2007
Posted 26 May 2011 - 07:45 PM
A small problem which i cant solve is the uneven tickover on my focus 2.0l tdi.
It is more noticable when engine is warm and i have tried egr cleaner and contact cleaner on airflow meter.
Any help or ideas will be appreciated.
Many Thanks
Paul
Have something to contribute?
#2 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 21,135 posts
  • Name: James
  • Year: 2007
Posted 27 May 2011 - 08:15 AM
Have you done a "basic service" replacing the fuel, oil, and air filter, checking fluid levels? is it more uneven under acceleration, or is it just under idle?
#3 MARLEY
MARLEY
  • New Member
  • 75 posts
  • Name: PAUL
  • Year: 2007
Posted 27 May 2011 - 06:07 PM
Thanks for reply, yes fuel oil and air all done, its a little lumpy on tickover only,(every 5 seconds or so) more noticable when engine is warm.
Thanks again
Paul
#4 digidash
digidash
  • New Member
  • 101 posts
  • Ford Model: cougar
  • Year: 2014
Posted 27 May 2011 - 09:50 PM
hi, please give full car details including year and mileage, thanks steve
#5 MARLEY
MARLEY
  • New Member
  • 75 posts
  • Name: PAUL
  • Year: 2007
Posted 28 May 2011 - 07:43 AM
hi steve
its a focus 2007 2.0l tdci and its got 54000 on the clock.
thanks
paul
#6 digidash
digidash
  • New Member
  • 101 posts
  • Year: 2014
Posted 28 May 2011 - 01:15 PM
hi, there is a known issue with throttle body o ring not fitted correctly when car made. also tps connectors. i would buy new o ring and a tin of carb cleaner....remove throttle body, clean and replace using new o ring ( part no 1 672 335) and a smear of grease to help seal. this is a cheap solution but could be anything from cam/crank sensor to an ecu, regards steve
#7 MARLEY
MARLEY
  • New Member
  • 75 posts
  • Name: PAUL
  • Year: 2007
Posted 28 May 2011 - 02:34 PM
Thanks again for your info Steve
Where is throttle body located and where shall i use the carb cleaner ? (its a diesel)
Paul
#8 digidash
digidash
  • New Member
  • 101 posts
  • Year: 2014
Posted 28 May 2011 - 07:13 PM
this is what it looks like..you will see it bolts to intake and has a fat rubber pipe pushed on and jubilee clipped. clean inside and butterfly flap to remove black crap. you can open flap with your hands.
1 make sure ignition off
undo/unbolt and disconnect unit
clean thouroughly
clean mating surface on intake
apply light spear of grease
fit new gasket
refit bolts finger tight then tighten em a bit at a time going from one to the one diagnally opposite like wheel nuts being EXTRA CAREFULL NOT TO OVER TIGHTEN as a stripped thread will make the job 10 times harder and 10 times more expensive!!
consider a local garage will probably do this for 20 ish
remember this may not cure it but it wont do any harm and as it costs pennies to do try cheap fixes first, regards steve
#9 Power of Dreams
Power of Dreams
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Name: Clifford
  • Ford Model: Ford Focus saloon 1.8 TDCI Titanium
Posted 09 April 2012 - 09:49 AM
Hi I have 2008 1.8 TDCI which will just stick on 150rpm whilst the car is moving, a bit disconcerting in traffic and around corners I have read the various posts on this subject and tried to locate the idle control valve etc without luck, so I'm resorting to buying a Haynes manual. I have had a look at all the hoses etc nothing appears split, any suggestions for someone who is new to Ford Diesels
#10 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 7,995 posts
  • Name: arthur
  • Year: 2006
Posted 09 April 2012 - 06:03 PM
stick at 150rpm do you mean 1500 rpm if so i can see why its disconcerting the butterfly valve in the throttle can get coked up and cause it to stick open slightly cleaning it will sort the issue.
if it was an icv issue you would get it more at idle a very uneven idle bouncing up and down
#11 Tim Chapman
Tim Chapman
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Name: Tim
  • Ford Model: Focus
  • Year: 2007
Posted 19 April 2012 - 09:42 AM
I seem to have the same issue with a 2007 2.0TDCI 53000 miles. (oil changed, air and fuel filter all replaced in the past few months)
I've looked a the throttle housing and can see what looks like a green seal behind it as one of the bolts doesn't look as tight as the others. - Is this the known build issue?
I've checked with a ford dealer and they don't show an o-ring or seal, mines a NON-DPF if this makes a difference.
Tim
#12 MARLEY
MARLEY
  • New Member
  • 75 posts
  • Name: PAUL
  • Year: 2007
Posted 19 April 2012 - 08:03 PM
Tim
Hi Tim
Have you any pics of where throttle housing is situated? will have a look to see if mine is loose.
Many Thanks
Paul
Not what you're looking for?
