P0700 And P0300 Fault
5 replies to this topic
#1 Mike Johnson
Mike Johnson
    Newbie
  • Pip
  • 3 posts
  • Name: Mike
  • Ford Model: Fiesta 1.4 Semi Auto
  • Year: 2003
Posted 05 June 2011 - 12:28 PM
Phew!!!!!
My 2003 Semi Auto 1.4 Fiesta has deveolped a fault.
History.. A couple of days ago, it simply would not start, this has to be done with the gear selector in neutral and foot on the brake. Fiddled about and bridged the plug which connects to the gear stick and hey presto it started and ran fine. parked up at the end of the day alls well. Next morning NOTHING... fiddled again and eventually after many attempts it started again and ran fine, stopped the engine a few times and it started fine. Tried it again this morning and NOTHING, got a mate to plug in his diagnostic gizmo and it shows a P0700 and P0300 fault. P0300 is mutiple misfire fault (engine wont run but could this be because the transmission is not sececting the correct gear)and the P0700 is TCM. When I switch on ignition, the Engine Management Light remains on but the transmission light will sometmes come on and other times not, if I move the stick about the light will eventually come on again.
Guess I am going to have to take it to Fords but has anyone any idears. I know electrical faults can be a sod to locate but I'm just a bit concerner it could be one of the very expensive bits that may have gone - but why would it run- when it does- with no obvious signs of a fault if this were so. What is the actuator, Fords tell me that could be £1000 to replace.
#2 Dieter
Dieter
    Newbie
  • Pip
  • 2 posts
  • Name: hermans
  • Ford Model: fiesta
  • Year: 2003
Posted 13 March 2013 - 06:06 PM
i've got a fiesta 2004 1.4d semi auto with just the same problem.
Sometimes the car doesn't start, other times it runs like there never was a problem.
The codes he gives are P0300 and P0700
Is your problem yet solvet? and what was the problem?
Hope you can help me  :)
I've been to the dealer but he doesn't see to find the problem...
#3 RickG
RickG
  • 55 posts
  • Ford Model: Focus Estate Econetic
Posted 13 March 2013 - 06:51 PM
That post was posted way back in 2011, so its unlikey they guy will be back to respond.
Hopefully someone else will have a suggestion for you :)
#4 Dieter
Dieter
    Newbie
  • Pip
  • 2 posts
  • Name: hermans
  • Year: 2003
Posted 13 March 2013 - 07:21 PM
Yes, i did see that but was hoping he would see it in his e-mail and could help me  :D
I guess the problem should be solved in 2years :P
#5 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,232 posts
  • Name: Daniel
  • Ford Model: Fiesta Mk6 1.3 Petrol
  • Year: 2003
Posted 14 March 2013 - 05:19 PM
As stated its likely the original poster has unsubscribed from recieving email notifications. Try posting your own topic in the fiesta section. Ill have a dig about and see what I can find out about the fault for you
#6 Mordey
Mordey
  • 113 posts
  • Ford Model: 2010 Fiesta zs
Posted 15 March 2013 - 03:38 PM
Mk6 Fiesta
P0300 Random/Multiple Cylinder Misfire Detected
PO700 Transmission control system malfunction
Whole list of codes on following link.
Go 3/4 way down page.
http://www.wikiwirra...BS_Air_Bag.html
