* * * * * 1 votes
Disable Esp On 5Dr Zetec 1.6 Tdci
199 replies to this topic
#91 adamc260
adamc260
  • New Member
  • 195 posts
  • Name: Adam
  • Ford Model: Fiesta Titanium 1.4 (3 Door)
  • Year: 2011
Posted 30 December 2011 - 02:16 PM
I well !Removed! of.Everyone on here says its an easy job you just pull it up.So I tried and one of the clips that no one mentioned that holds the two sections together snapped clean in half so I not trying again...
What clip is that mate? :/
Have something to contribute?
#92 kevin lancelott
kevin lancelott
  • Budding Enthusiast
  • 366 posts
  • Name: kevin
  • Ford Model: Focus Titanium X 1.6 tdci
  • Year: 2013
Posted 30 December 2011 - 02:22 PM
On the gaiter surround there are 4 clips,two either side that hold it in place.I knew about these ones and they come out easily when you pull up from the back edge but no one mentioned about the two on the corners of the front edge just behind the join line between the gaiter and other piece of gray plastic so my drivers side one snapped as I was pulling upward on the gaiter once the 4 side clips was out.
#93 adamc260
adamc260
  • New Member
  • 195 posts
  • Name: Adam
  • Year: 2011
Posted 30 December 2011 - 02:25 PM
Because i looked on that video and it only highlights the 4 clips? Can you take a pic mate?
#94 kevin lancelott
kevin lancelott
  • 366 posts
  • Name: kevin
  • Year: 2013
Posted 30 December 2011 - 02:30 PM
No chance.I don't want to risk taking it off again.The side with the clip doesn't quiet fit as snug as it did.I knew something would happen if I tried removing trim parts of my car.I so !Removed! off now its unreal.How come it was so easy for every one else. :angry: :(
#95 adamc260
adamc260
  • New Member
  • 195 posts
  • Name: Adam
  • Year: 2011
Posted 30 December 2011 - 02:35 PM
So you have the 4 clips as shown by the circles, are there clips where the question marks are too is that what you mean or?
#96 kevin lancelott
kevin lancelott
  • 366 posts
  • Name: kevin
  • Year: 2013
Posted 30 December 2011 - 02:41 PM
Yes that's them right up by the join line.They fasten through the base of the other plastic.Once you have removed the other 4 these 2 stop you from removing the gaiter and you cannot see how to get them out either.
#97 adamc260
adamc260
  • New Member
  • 195 posts
  • Name: Adam
  • Year: 2011
Posted 30 December 2011 - 02:55 PM
How are you meant to remove the plastic bit surrounding the gear stick then if those 2 stop you from doing it? =/
On the german forum someone has this as a picture
#98 kevin lancelott
kevin lancelott
  • 366 posts
  • Name: kevin
  • Year: 2013
Posted 30 December 2011 - 02:57 PM
Exactly.I saw that same pic as well.If I know how to get it off I suppose I could get a new one from ford.
#99 adamc260
adamc260
  • New Member
  • 195 posts
  • Name: Adam
  • Year: 2011
Posted 30 December 2011 - 02:59 PM
Hope my dad will be able to do it now, everyone else said its easy to do once you remove those 4 clips? =/
#100 kevin lancelott
kevin lancelott
  • 366 posts
  • Name: kevin
  • Year: 2013
Posted 30 December 2011 - 03:01 PM
Them 4 simple to remove clips. :D :angry:
#101 adamc260
adamc260
  • New Member
  • 195 posts
  • Name: Adam
  • Year: 2011
Posted 30 December 2011 - 03:03 PM
Will let you know how it goes, may be in the same position as you in a few days mate! Did you try lifting the plastic section up from the bit that meets the centre console or from the bit nearest the handbrake?
#102 kevin lancelott
kevin lancelott
  • 366 posts
  • Name: kevin
  • Year: 2013
Posted 30 December 2011 - 03:06 PM
From the back by the handbrake then the two sides at the same time.Thats when it would go no more because of the front ones that I didn't know about so I was trying to pull upwards when one snapped.
#103 adamc260
adamc260
  • New Member
  • 195 posts
  • Name: Adam
  • Year: 2011
Posted 30 December 2011 - 03:11 PM
The picture looks as if its best to do it from the front, may try that way first just in case lol =/ Cheers mate! Sorry to hear of your problems :(
#104 kevin lancelott
kevin lancelott
  • 366 posts
  • Name: kevin
  • Year: 2013
Posted 30 December 2011 - 03:12 PM
Let me know how it goes.
#105 adamc260
adamc260
  • New Member
  • 195 posts
  • Name: Adam
  • Year: 2011
Posted 30 December 2011 - 03:14 PM
Will do! If my dad can't do it his mate who owns a garage will have a look at it for me! They're quite heavy handed too though =/
Not what you're looking for?
