Battery Hell
8 replies to this topic
#1 Robgrace
Robgrace
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: Robert
  • Ford Model: Mondeo
  • Year: 2002
Posted 10 June 2011 - 08:55 PM
Hi all,
I have a 2002 mondeo zetec 1.8.my battery went dead and I got it replaced. Same thing again.I brought it to my mechanic who tested the battery when the car was off.it gave a reading of 5amps. All lights,fuses,radio etc were checked and it's not them. Alternator was disconnected and reconnected but problem still there. Alternator is working fine. Mechanic said it could be something to do with the central locking? Does anyone know why this car us draining the battery? Cheers rob
Have something to contribute?
#2 mr pompey
mr pompey
  • New Member
  • 81 posts
  • Ford Model: st24
Posted 11 June 2011 - 07:28 PM
i would have the alternater rechecked, or check the earthing points,
would also check the battery while the car is running,(with all lights on aswell) as it sounds like the alternater is not chargeing the battery up
#3 Robgrace
Robgrace
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: Robert
  • Year: 2002
Posted 12 June 2011 - 02:03 PM
Hi thanks for the reply will let you know if it works cheers
#4 fully focused
fully focused
    Member
  • New Member
  • PipPip
  • 18 posts
  • Ford Model: Focus
Posted 13 June 2011 - 08:20 AM
I'd also check the alternator regulator.
#5 Robgrace
Robgrace
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: Robert
  • Year: 2002
Posted 14 June 2011 - 07:50 PM
Hi all, mechanic got an auto electrician into have a look at it.he spent an hour and a half on it did all the fuses, interior lights etc, battery still giving reading of 5amps, auto electrician thought it could be a problem with the central locking, mechanic checked this out but wasn't it. The car battery is showing a minimal reading as is normal but will go up in amps again, he said he is stuck and told me to bring it to an auto electrician specialist, the original auto electrician is away on holidays now. Has anyone had this trouble? Thanks
#6 chris bowman
chris bowman
  • New Member
  • 255 posts
  • Ford Model: ford mondeo 2.0lx tdci 115
Posted 15 June 2011 - 06:06 PM
my mkii mondeo 1.8 petrol used to retire a new battery every 2 years! i never got to the bottom of it! got wierd symptoms when it was playing up aswell. whentrying to start the car as the engine turne over slowly, the wipers used to sweep slowly even when they were turned off??? the first hint i ever got however was the central locking being really sluggish. ie unlocking one door after the other over about 4 seconds instead of almost instantaneously. there was obviously something wrong with the electrics but never got to the bottom of it before i got rid of it. u could disconnect the central locking as the module is above the drivers footwell and see if it makes a difference over a few days
#7 Robgrace
Robgrace
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: Robert
  • Year: 2002
Posted 15 June 2011 - 08:42 PM
This was done with the central locking but still amps running to the battery. I'm leaving it into an auto electricians garage to hopefully get it sorted. I'll let you know what the problem is! Thanks for the replys
#8 cuke
cuke
  • True Ford Enthusiast
  • 728 posts
  • Name: Chris
  • Ford Model: Mk3 Focus Titanium X
  • Year: 2011
Posted 16 June 2011 - 04:23 PM
Hi, so it isn't the alternator draining the battery? They are well known for doing this, although you say amps are running to the battery, don't you mean from???
Chris
#9 chris bowman
chris bowman
  • New Member
  • 255 posts
Posted 16 June 2011 - 10:03 PM
in my mkii though i didnt find the cause, my battery wasnt holding its charge over night. but despite this registered nearly 14 volts but useless and pathetic amperage which is more importatnt
Not what you're looking for?
