Support the club!
TDCI Clutch
1 reply to this topic
#1 Magic
Magic
    Newbie
  • Pip
  • 1 posts
  • Ford Model: Mondeo TDCI 130 Est
Posted 06 December 2008 - 07:58 AM
Hi all-cracking forum...its already answered one of my issues....rubbish warm-up (the 2nd stat that my local Ford garage didnt even mention!!!).
Anyways....bought my 04 TDCI 130 est a few months ago and noticed the clutch was very sharp and juddery.  Got the supplier to cough up for a clutch and rel bearing and DMF so its loads smoother now.
Trouble now is the pedal/bite point is still quite low (it was before the new clutch was fitted).  I have to push the pedal nearly to the floor to clear and the bite points about 1/2 " off the floor.
I did notice the brake lights coming on when the clutch was down too so I bent the switch bracket a bit to cure that.  There doesnt appear to be excess play in the pedal box (which I thought may be a link between both probs).
Any ideas guys???
Cheers
Ade
#2 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,330 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 06 December 2008 - 03:32 PM
it sounds like air has got into the system a good bleed might sort it out, If you look down on top of the gearbox where the hydraulic pipe connects into the box itself, you should see a bleed nipple, probably hidden behind a little rubber boot.
