sypics Posted June 19, 2011 Share Posted June 19, 2011 54 plate ford focus tdci 115 ps started cutting out on motorway radio would go off and come back on instantly all lights would come on then go out then engine cut and start then would drive normally talked to mech said they had fleet of tranis etc all had lights come on just ignore it they could never find problem well he was wrong now when you turn ignition on lights come on go out both rev counter and speedo flicker up and down only light that has stopped coming on is glow plug light engine turns but will not start???? has any one any idea? just put clutch in not got much left :( Quote Link to comment Share on other sites More sharing options...
mintalkin Posted June 19, 2011 Share Posted June 19, 2011 i would start by checking battery terminals and all the earth points you can find to see if they are clean, good and tight. Quote Link to comment Share on other sites More sharing options...
sypics Posted June 19, 2011 Author Share Posted June 19, 2011 done all that battery 12.45v not running same as my van tried jumping it no its not prefferd but if battery not up to it thought might sort it out and it didnt when you turn it over though sounds like flat battery way it turns over Quote Link to comment Share on other sites More sharing options...
sypics Posted June 27, 2011 Author Share Posted June 27, 2011 sorted it took starter off and cleaned terminals etc found a problem that I had missed first time sorted :) Quote Link to comment Share on other sites More sharing options...
catch Posted June 27, 2011 Share Posted June 27, 2011 found a problem that I had missed first time sorted :) And that problem was ? Here's your chance to extend the knowledge base of the forum......go on Shine :) Quote Link to comment Share on other sites More sharing options...
