Ford Fiesta 1.25 Zetec Lx W-Reg
Where to start...
New engine not too long ago, was running fine until the coil pack went...
Mis-firing etc, drove it around 1,000 miles with the misfire - an expensive mistake...
Replaced coils, HT leads, spark plugs... run well for a bit then:
un-burnt fuel in the cat.... and well, it melted... Huge pressure in the exhaust, VERY rough, failed to start most times often took up to 2 mins to try to start it.. so:
New exhaust, sensors etc but it is not running right...
the whole car shakes badly, sparks are all good, there is fuel, timing is good...
So i thought it might be the ecu, or if not at least read any error codes, so i bought an OBD2 lead and got some software to read the ecu,
This lead is compatible with OBD, OBD2 and EOBD, and supports all OBD2 protocols...
The software and lead works with all are other cars, including parents ford galaxy, fiat punto etc
But when i plug it into the ford fiesta i get many error messages - differnt depending with which software i use:
1. - no response from ecu
2. - Unable to connect
3. - No response from interface
4. - Unsupported protocol
No issues with any other car when using this lead & any of the programs i have... English model, 3 door manual 5 speed
What protocols does the 2000 (w-Reg) ford fiesta Zetec LX (Zetec - SE engine 1.25L) ecu use and what connection is it meant to be?
I am using a 16 pin ELM 327 lead with ScanMaster-ELM
Cheers all
Latest Comments
More
