Wind/air Leak
9 replies to this topic
#1 Kapz K
Kapz K
    Newbie
  • New Member
  • Pip
  • 9 posts
  • Name: Kapil
  • Ford Model: Focus 1.6 Ink
  • Year: 2003
Posted 27 June 2011 - 04:09 PM
Hi all,
Just purchased a used Ford Focus 1.6. Amongst other minor problems this seems to be the most annoying :@
When I am driving at speed, around 50 mph +, this irritating noise begins to come from the driver side door, as though a window is open. I've checked all the windows and I've checked the seals. To my knowledge, these seem all intact with no obvious rips or disconnections.
I was sitting in the back seat of the car on one journey and I discovered there was actually a breeze/draft of some sort coming in through what seemed to be the rear window (it is a 3 door so I can't actually check for any seals on the rear window).
I've taken it to a garage and they've said tape up the door and rear window with insulation tape and drive around and remove the tape piece by piece until the sound returns. I find this will be a time consuming and possibly pointless process, especially being on the driver side...and me being 6 ft 3 its gonna be a bit of a struggle to get into the drivers seat through the passenger side.
Another Ford specialist garage I went to today was going to charge me £30 just for diagnostics which I'm not prepared to pay until I know its a problem worth fixing.
Could somebody please point me in the right direction as to what it possibly could be?
Have something to contribute?
#2 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 7,933 posts
  • Name: arthur
  • Year: 2006
Posted 27 June 2011 - 04:17 PM
Hi all,
sound advice from the garage the only other option is to remove the doorcard and see if the lining has been ripped or removed its usually a worn door seal it will be intact but will have over the years lost its efficiencyanother option is the foam seal behind the door mirror has gone letting wind through
#3 Kapz K
Kapz K
    Newbie
  • New Member
  • Pip
  • 9 posts
  • Name: Kapil
  • Year: 2003
Posted 27 June 2011 - 04:21 PM
The foam seal...you have jogged my memory. I do remember the grey foam seal was slightly hanging off. Maybe the upper 5-6mm is not stuck on anymore. Whereas the passenger side is firmly attached. About removing the door seal. Still learning about cars, only just started off (this is my first car), do you mind maybe showing me exactly which part you are talking about. I will try sticking the foam seal back up. Would super glue do the trick, or am I naive to suggest that?
Thanks for the prompt reply!
#4 H3lly
H3lly
  • New Member
  • 282 posts
  • Name: k
  • Ford Model: Mk1 Focus
  • Year: 2003
Posted 27 June 2011 - 04:29 PM
It could be the door rubber that's perished a bit allowing road and wind noise into the car. Check each door rubber if it's out of shape. It shouldn't be a difficult job to replace them.
#5 Kapz K
Kapz K
    Newbie
  • New Member
  • Pip
  • 9 posts
  • Name: Kapil
  • Year: 2003
Posted 27 June 2011 - 04:37 PM
if it is the driver door causing the problem i.e. rubber weatherseals or the foam behind the wing mirror, what would explain the breeze when I was sitting in the rear seat?
#6 artscot79
artscot79
  • PipPipPipPipPip
  • 7,933 posts
  • Name: arthur
  • Year: 2006
Posted 27 June 2011 - 07:20 PM
ide use clear silicone for the foam seal rather than superglue remove the mirror from the car and reattatch the foam seal with the silicone then fit while the silicone is still tacky as for the door seal they do wear down over time and dont seal right the big black rubber bit round the inside of the door sim ple to replace they just pull off ide try the mirror first and see how it goes
#7 Kapz K
Kapz K
    Newbie
  • New Member
  • Pip
  • 9 posts
  • Name: Kapil
  • Year: 2003
Posted 27 June 2011 - 08:07 PM
okay...you've stumped me. Are we talking about the grey piece of sponge/foam that is glued to the inner side of the door between the door and wing mirror, or actually upon removing the actual wing mirror and triangular shaped plastic bezel (upon which the remote control for the mirror is situated) there is another foam that is not visible until after opening the wing mirror?
#8 artscot79
artscot79
  • PipPipPipPipPip
  • 7,933 posts
  • Name: arthur
  • Year: 2006
Posted 28 June 2011 - 08:21 PM
there should be a foam seal under the wing mirror baseplate as well as foam at the back of the door card ide try the wing mirror and door card first before considering anything else
#9 Kapz K
Kapz K
    Newbie
  • New Member
  • Pip
  • 9 posts
  • Name: Kapil
  • Year: 2003
Posted 29 June 2011 - 10:43 PM
Hi, I opened up the wing mirror today and noticed two things upon comparing it to the mirror on the other side.
1 - The square piece of foam behind the triangle bezel on the interior was missing (this http://cgi.ebay.co.u...=item43a4f0bb0b)
2 - Upon removing the mirror itself on the exterior, the wing mirror baseplate foam was all tacky and half torn
It looks like somebody has replaced the mirror and placed no foam back. I tore off the battered foam that was behind the baseplate. Now my question is can I just place clear silicon around the border of the baseplate and firmly attach it on and not have to worry about placing foam there as well, and would I need to place foam inside the triangular plastic bezel on the interior as that is missing. Sorry if this is unclear, if so I can provide photos
#10 Nigel S
Nigel S
  • New Member
  • 146 posts
  • Name: Nigel
  • Ford Model: Focus Mk 2 2.0 Zetec Climate
  • Year: 2005
Posted 30 June 2011 - 07:22 AM
You may need a new mirror. They are not expensive and you can swap the painted back over.
Not what you're looking for?
