Ford 3 Button
7 replies to this topic
#1 DAM13N
DAM13N
  • New Member
  • 68 posts
  • Ford Model: Ford Focus Zetec
Posted 07 July 2011 - 03:33 PM
Hi All
Ford Focus 1.8 TDCI Ghia 2003 52 Plate
I'm Having trouble coding a 3 Button Flip Key into the Immobilisor. I can code it so it unlocks/ locks all doors and the boot however i can not code it to start the car.
i have done what it states to do in the manual. Insert KEY A to position 2 and remove then Insert KEY B to position 2 and remove then Insert The uncoded key in the ignition to position 2.
however nothing happens i cannot start the car,
the key works fine e.g when i split the key so i have just the KEY not the remote and put it in the ignition it turns and starts the car when i put the original key near the immobilsor.
any ideas folks???
Cheers Damien
Have something to contribute?
#2 Nigel S
Nigel S
  • New Member
  • 146 posts
  • Name: Nigel
  • Ford Model: Focus Mk 2 2.0 Zetec Climate
  • Year: 2005
Posted 07 July 2011 - 03:53 PM
You need two keys already programed in and present to code in further ones to be able start the car.
#3 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 7,940 posts
  • Name: arthur
  • Year: 2006
Posted 07 July 2011 - 07:16 PM
he is very correct you need the master key with the blue square on it and a programmed key otherwise you cant code it youreself and the flip keys look good but they are junk pins that hold the thing together constantly bend
#4 DAM13N
DAM13N
  • New Member
  • 68 posts
Posted 10 July 2011 - 08:50 PM
Hi Guys,
I do have the master key present and a standard 3 button remote, i am coding it in the right way however it really doesnt seem to register, i have followed the ford manual direct as anything.
I have previsouly coded a jaguar kay into my zetec before my tdci gear and that worked perfectly..
this just seems a little strange...
cheers for your help thou guys
Damien
#5 artscot79
artscot79
  • PipPipPipPipPip
  • 7,940 posts
  • Name: arthur
  • Year: 2006
Posted 10 July 2011 - 09:34 PM
Hi Guys,
Damien
so you have an original key for the car and the master key as well as you need both to do it is this a jag flip key youre trying to programme it could be you havr the max amount of keys programmed to the car
#6 stef123
stef123
  • Management
  • 5,806 posts
  • Name: Stefan
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 10 July 2011 - 10:20 PM
Is it the correct chip in the new key you are trying to code?
As far as i know even if the car has the max amount of keys programmed to it, if they are not present when you program another they will be excluded anyway..
#7 DAM13N
DAM13N
  • New Member
  • 68 posts
Posted 12 July 2011 - 07:51 PM
Hi
I have the Master Key, with the Blue chip on the top and the standard 3 button remote key. I am trying to code a new ford 3 button flip key.
on my previous car a focus 1.6 zetec X reg, i coded a jaguar key 1st into that with out any issues.
The new ford 3 button flip key, is coding with the central locking so i can lock and unlock all of the doors/boot, and use the global function for the windows. it just wont code to immobiliser.
The new ford 3 button flip key was previously used on a ford focus 57 plate i believe, i bought this off ebay complete with the key attachment, however i discarded this and bought a modified "Tibbe" key to fit with the flip.
Any ideas and your help is much appreciated
Damien
#8 artscot79
artscot79
  • PipPipPipPipPip
  • 7,940 posts
  • Name: arthur
  • Year: 2006
Posted 12 July 2011 - 08:00 PM
Hi
Damien
i could be wrong but i remember reading that the chips on the newer kys dont work with the older cars and so wont programme
Not what you're looking for?
