mk2 xr2 intermittent stalling problem
colchesterscott
:angry: hi folks my e reg xr2 has an intermittent stalling problem it only does it now and then .id be driveing fine then as i go to stop at a junction it just dies it starts right away when turn key and if i rev it as it goes to stall its fine soon as let throttle go it stalls then start up again drives perfect its doing my head in anyone else had this fault im certain it must be a carb fault or something thanks scotty :P
hey m8 check the airfilter and any pipes vaccum leaks around the carb its probably something and nothing like a cracked pipe
h im mates mark 5 did the exact same thing he found his fuel pump was damaged and somthng to do with the air iinlet.
hope it helps.
