Sat Nav
9 replies to this topic
#1 SCWallace
SCWallace
    Newbie
  • New Member
  • Pip
  • 3 posts
  • Name: Scott
  • Ford Model: Focus
  • Year: 2009
Posted 20 July 2011 - 08:54 PM
Hi Everyone,
I've just purchased a 2009 Focus Titanium with Blaupunkt Sat Nav but no matter what i do it doesn't pick up a GPS signal, anyone got any ideas?
Have something to contribute?
#2 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,664 posts
  • Name: James
  • Year: 2007
Posted 21 July 2011 - 07:04 AM
Hi Everyone,
whereabouts are the antenna's bedded for the GPS side? could be a loose connection between them.
Since the cars an 09 plate - get it checked out under warranty, call Ford first, make sure theres nothing obvious they can advise over the phone.
#3 SCWallace
SCWallace
    Newbie
  • New Member
  • Pip
  • 3 posts
  • Name: Scott
  • Ford Model: Focus
  • Year: 2009
Posted 21 July 2011 - 08:02 AM
Thanks, as i only picked it up yesterday and there is no Sat Nav Manual i thought it might be something i was doing wrong, i'll give the dealer a call.... Thanks
#4 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,543 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 21 July 2011 - 03:09 PM
the gps is picked up from the aerial base si it could be a bad connection there.
#5 btmaldon
btmaldon
  • PipPipPipPipPip
  • 2,581 posts
  • Name: Bruce
  • Ford Model: BMW 320i Coupe M Sport, KA Luxury
Posted 21 July 2011 - 03:15 PM
Have you got the memory card with the software on it, in the slot?
#6 john kenny
john kenny
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Name: john
  • Ford Model: C Max
  • Year: 2009
Posted 03 June 2013 - 10:41 AM
Hi just wanted to know if you got this GPS issue resolved?  I am having exactly the same problem on my C-Max 09, so wanted to know if you found out where the issue lies?
Please let me know as it will help me fix mine, if you fixed yours it will be really helpful to know what the problem was so i can check that on mine.
I have checked the Connections on rear of sat nav / audio unit, but was unsure where the GPS antenna was?  Is it definately the base of where the Radio aerial screws into?
Or if anyone else reading this can point me in the right direction id really appreciate it.
thanks
JK
#7 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,664 posts
  • Name: James
  • Year: 2007
Posted 03 June 2013 - 08:48 PM
Unfortunately the OP hasnt been on since July 2011. I dont think you will get clarification to your request for an update JK
#8 john kenny
john kenny
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Name: john
  • Ford Model: C Max
  • Year: 2009
Posted 04 June 2013 - 09:26 AM
thanks
JK
Can anyone else help me with this issue?
#9 ccurts
ccurts
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Name: Christopher
  • Ford Model: Focus Sport 1.6 Petrol
  • Year: 2011
Posted 16 June 2013 - 10:24 PM
Or me??
Just had my Focus sport 2011 over a week and annoyed that Sat Nav not working. When I press "i" button next to display it says in red "No GPS 43m"
#10 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,664 posts
  • Name: James
  • Year: 2007
Posted 17 June 2013 - 12:58 PM
I would say take the roof lining off if possible and check the connection to the antenna is fine, it could be a loose connection, or even a corroded connection on the inside (if moisture has gotten through the seal and worked in the headlining). Otherwise it sounds like you may need to replace the antenna mount.
Chris, as yours is a 2011, you should get it to the dealer ASAP, it should be a warranty repair!
Not what you're looking for?
