Bad Starter
10 replies to this topic
#1 MARLEY
MARLEY
  • New Member
  • 75 posts
  • Name: PAUL
  • Ford Model: MK2 FOCUS 2.0 TDCI GHIA
  • Year: 2007
Posted 22 July 2011 - 05:44 PM
Hi All
My focus 2.0l tdci is really strugling to start once it is warm, if i keep ignition key turned it will eventually run.I have checked all pipes and fittings etc and all seems ok, the only other thing it does is hesitate on tickover every 5 seconds or so.
Any help or advice will be appreciated
Thanks in advance
Paul
Stalybridge
Have something to contribute?
#2 johnH
johnH
  • 1,137 posts
  • Name: John
  • Ford Model: Focus mk2 Zetec 1.8 TDCI (Climate)
  • Year: 2006
Posted 22 July 2011 - 06:02 PM
i would check your fuel filter, easiest and cheapest place to start.
#3 MARLEY
MARLEY
  • New Member
  • 75 posts
  • Name: PAUL
  • Year: 2007
Posted 22 July 2011 - 06:06 PM
I have already changed fuel filter and made no difference, its one of those annoying little problems which will eventually get sorted
#4 stef123
stef123
  • Management
  • 5,808 posts
  • Name: Stefan
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 22 July 2011 - 06:22 PM
crankshaft sensor?
#5 MARLEY
MARLEY
  • New Member
  • 75 posts
  • Name: PAUL
  • Year: 2007
Posted 22 July 2011 - 07:26 PM
crankshaft sensor?
thanks for reply
where is it located and can it be tested ??
#6 stef123
stef123
  • Management
  • 5,808 posts
  • Name: Stefan
  • Year: 2006
Posted 22 July 2011 - 08:01 PM
thanks for reply
Its located where the gearbox meets the engine, it picks up a signal from the flywheel.
Not entirely sure if it can be tested though im afraid.
#7 MARLEY
MARLEY
  • New Member
  • 75 posts
  • Name: PAUL
  • Year: 2007
Posted 22 July 2011 - 08:26 PM
will have a look in morning, hopefully no rain,
if it is faulty will it cause problems starting ??
i was thinking a fuel problem.
a quick test would be to swap sensors with another focus.
Regards
Paul
#8 stef123
stef123
  • Management
  • 5,808 posts
  • Name: Stefan
  • Year: 2006
Posted 22 July 2011 - 09:17 PM
Regards
Paul
I've not heard of many problems with them on the focus but certainly other cars, and causing poor running when the sensor gets hot - starts breaking down
certainly swapping the sensor or getting one from a breakers yard would help.
#9 MARLEY
MARLEY
  • New Member
  • 75 posts
  • Name: PAUL
  • Year: 2007
Posted 22 July 2011 - 10:03 PM
I have just done the test where you hold the set button in and turn ignition on, everything is fine with no codes,
ps does anybody know where my EGR VALVE is located 2007 2.0l tdci ???
thanks
Paul
#10 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 21,020 posts
  • Name: James
  • Year: 2007
Posted 24 July 2011 - 09:25 AM
if im right, its at the back of the engine block closest to the cabin.
#11 MARLEY
MARLEY
  • New Member
  • 75 posts
  • Name: PAUL
  • Year: 2007
Posted 24 July 2011 - 09:28 AM
thanks for reply.
will get up on ramps and have a look,
will let you know how i get on
Paul
Not what you're looking for?
