smithy1989 Posted July 25, 2011 Share Posted July 25, 2011 I have just bought a 2003 5 door 1.4 zetec fiesta and the passenger window will not work with the electric windows. The lad i bought it from said it was a common fault with fiesta is this true? What is the best way of fixing the problem. Cheers in advance Kyle. Quote Link to comment Share on other sites More sharing options...
D4nz0 Posted July 26, 2011 Share Posted July 26, 2011 it'll probs just be the window motor. I had this fault with my 53 plate focus. Take the door to bits and make sure the connections are ok, if they are just buy one from eBay from someone breaking an 03 Fez and replace it. I don't think it can be anything else really Quote Link to comment Share on other sites More sharing options...
dLockers Posted July 27, 2011 Share Posted July 27, 2011 If you were located closer I could have sorted you a new door motor. I'd say its not common at all personally. Quote Link to comment Share on other sites More sharing options...
FordGirl78 Posted April 19, 2014 Share Posted April 19, 2014 Hi all, I have a 2003, 3 door mk6 fiesta. The electric window goes down but not up! I have replaced the regulator and switch and checked the connections but the regulator will only go down??? I have checked drivers door window works perfectly but the drivers door switch for passenger door doesn't work at all.... Any ideas anyone I'm stuck??? Quote Link to comment Share on other sites More sharing options...
