I own a 2008 smax and two weeks ago started having the following problem. The dealer has no clue and is trying various things to no avail for 4 days already.
The issue is that about an hour after I turn off the ignition, the break lights on the right side are turning on. It can take 30 min or couple hours and sometimes it doesn't happen at all but I had situations when it turned on all night.
I noticed that when it happens and I tuern the ignition on, the right signal is blinking. The way to turn it off it to turn the lights on and off while ignition is off.
Has anyone ever seen this problem?
Right Break Light Turn On While Ignition Off
Started by Razdar, Jul 30 2011 12:42 PM
2 replies to this topic
#1
Posted 30 July 2011 - 12:42 PM
#2
Posted 30 July 2011 - 02:08 PM
it is a knwown issue with the Smax which ford know about, fiting a new indicator stalk should resolve the issue.
#3
Posted 01 August 2011 - 04:33 PM
The light you're seeing at the back is the "parking" light - which suggests the car thinks you left the indicator switched pointing right. As mintalkin suggests, sounds very much like a defective indicator switch/stalk.
