Mondeo Estate 2003 2.0Tdci Wont Start
4 replies to this topic
#1 dazg
dazg
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: darren
  • Ford Model: mondeo 2.0TDCI
  • Year: 2003
Posted 02 August 2011 - 04:26 PM
Hi all,
I have a 2003 mondeo estate 2.0TDCI, It wont start and when turning the key to position 2 nothing happens, I get the lights on the dash and mileage comes up but no sound from anything including the starter motor. I have checked the battery and its fine and no fuses are blown. When i turn the key to position 3 the mileage goes off and nothing again. I have tried bump starting and jump starting but nothing. All i can think is maybe something as earthed out or a wire has come loose but i cannot find anything to prove this. Any help would be very much appreciated thank you.
Have something to contribute?
#2 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,626 posts
  • Name: James
  • Year: 2007
Posted 02 August 2011 - 04:38 PM
Hi all,
Get your multimeter out, put the car to electrics and see if there is any current going to the starter motor, as its not turning at all, I suspect that it could have a broken wire. the earth (I dont believe) would stop your car doing all this all together. having said that, I could be wrong.
#3 dazg
dazg
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: darren
  • Year: 2003
Posted 02 August 2011 - 05:29 PM
Thank you for your response, As long as i have tested the correct wire i got no reading from it. I checked the wire that went into the side of the starter motor and was in red casing.
#4 dazg
dazg
    Newbie
  • New Member
  • Pip
  • 8 posts
  • Name: darren
  • Year: 2003
Posted 02 August 2011 - 06:36 PM
Just checked and yes its the starter motor. The only thing is there is a live that goes straight to it from the battery and one that goes from the fuse box, i don't understand why that would be like that.
#5 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,626 posts
  • Name: James
  • Year: 2007
Posted 02 August 2011 - 08:59 PM
so there is no current going to the starter from what you just checked?
If thats the case I am a bit curious if you say the battery is ok and there is a live wire straight from there through to the starter and you touched the main contact point, is the wire boken at all?
As for going to the glovebox, I am not sure why... just check for breaks in the cabling, and make sure that the battery definitaly is good.
Not what you're looking for?
