96 Fiesta Air Filter Permanently Clogged Up
7 replies to this topic
#1 matt1985uk
matt1985uk
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Name: Matthew
  • Ford Model: Fiesta
  • Year: 1996
Posted 03 August 2011 - 08:08 AM
Hi, i have a 1996 1.4 Fiesta and im having problems with the air filter getting clogged up with gunk, it comes down from the breather pipe that runs from the oil filler cap to the air filter box, have changed all the parts in the past and the same thing just happens again, i must have the only car in the world that leaks oil from the air filter. Anyone else had this problem or knows how to sort it out would be greatly appreciated,
Thanks.
Have something to contribute?
#2 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,559 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 03 August 2011 - 02:59 PM
sounds like the car has blocked P.C.V valve.
#3 matt1985uk
matt1985uk
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Name: Matthew
  • Year: 1996
Posted 07 August 2011 - 08:17 PM
And what is that sorry? Also is it easy/cheap to replace? Thanks.
#4 matt1985uk
matt1985uk
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Name: Matthew
  • Year: 1996
Posted 07 August 2011 - 08:33 PM
Just found out what is is on google, easy to replace?
#5 stef123
stef123
  • Management
  • 5,871 posts
  • Name: Stefan
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 07 August 2011 - 08:38 PM
sounds to me like the pcv valve is stuck open.
Its a little plastic one way valve that allows the engine to breathe by letting out combustion gases. I had to replace one on my last car (focus) and the valve only cost about a fiver, if that.
If you follow the breather hose from the airbox, you will find the valve.
#6 matt1985uk
matt1985uk
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Name: Matthew
  • Year: 1996
Posted 08 August 2011 - 09:12 AM
I have looked around my engine for where the PCV valve was located it but couldn't see but i just read on another forum that its located in the oil filler cap, which i guess might be true as mine has breathers coming off it, one from the air box. Any ideas if this is true? It is an Endura E engine.
#7 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,559 posts
  • Name: mintalkin
  • Year: 2006
Posted 08 August 2011 - 08:00 PM
if its under the filler cap there will be a flame trap made up of wire gauze and also a PCV valve. sometimes they have the PCV valve inside the air cleaner housing.It looks like a little flat rubber mushroom.
#8 matt1985uk
matt1985uk
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Name: Matthew
  • Year: 1996
Posted 09 August 2011 - 06:40 AM
Yep thats what its like, i've got a new one from a car parts shop as Ford kept ordering me the wrong part, according to them the oil filler cap i have doesn't even exxist lol, i've fitted it so hopefully iy will be ok.
Not what you're looking for?
