ST170 engine light on but no fault code
Started by Defender9, Dec 21 2008 09:01 PM
7 replies to this topic
#1
Posted 21 December 2008 - 09:01 PM
I wondered if anyone knows why my engine light is still on ?.
I have done the test and there is no fault codes showing but the light still remains on.
Anyone have any clues?
#2
Posted 22 December 2008 - 01:26 PM
the fault might have not stored itself, reset the light and see if it returns.
#3
Posted 22 December 2008 - 02:51 PM
Thanks for that but how do you reset the light as i'm new to these, I'm normally a land rover man.
Cheers.
Cheers.
#4
Posted 22 December 2008 - 06:27 PM
if you remove fuse 26 for about 30mins this should reset the ecu and probubly the light with it, if this fails it will have to be cleared with a code reader.
#5
Posted 22 December 2008 - 08:13 PM
Thanks for that, I'll try it and let you know.
#6
Posted 23 December 2008 - 05:18 PM
Worth bearing in mind, the dash trick doesnt always store ECU fault codes. Best bet is to get a proper code read done. I had an airbag light on and no dash dTC code on my focus TDi. Got my breakdown company out (free code read as Ford wanted £70) as I wasnt at home and didnt want an airbag in my face. Turned out there was a fault code on the ECU even though it didnt show on the dash interface.
#7
Posted 23 December 2008 - 07:14 PM
Thats good to know, I'll give that a try after Christmas,
Did they tell you the fault and did they fix it?
Many thanks.
Many thanks.
#8
Posted 24 December 2008 - 11:08 AM
Many thanks.
Yep, airbag control module faulty or switched off and no they didnt fix it. £140 for part from Ford plus labour to fit it and programme it to the car.
