Timbo343
Bluetooth - Phone Directory Empty
9 posts in this topic
I have a Nokia N79 and when i try to call someone via the bluetooth in the car it says Directory empty but yet it displays who is calling when someone rings.
Is there a way to transfer the names over or is it a case my phone is too old?
Are you trying to use voice dialling? I believe you have to manually add the contact's name and number into the car's phone directory so that you can use the "dial name - marmaduke" feature.
The contacts are prob saved to your sim memory and they have to be on your phone memory for the car to load them up.(if that don't work its visa versa lol)
I have a fiesta MK7 and my radio said directory empty, and would not let me call via phonebook,
it seems the car system it has its own directory
I have to press the voice button
then say STORE NAME then she says NAME PLEASE then i say the name eg LEE
then she asks for the NUMBER so you tell it the number
then she says stored or something similar, then u can voice dial that name
since then I am able to use name dialling
hope this helps
as it took me a while to suss why i could not use my phonebook from my phone
as irononreverse post
Thanks for sharing the info mate, I was wondering the same thing yesterday after I managed to connect the phone to the Ford audio, but was to lazy to search for an answer.
is this the only way, it will take hours if you have say 60 or more numbers?
thank you.
Yes it is the only way , if your going to use the Ford voice control
thank you.
I believe it has a maximum capacity of around 20 names/numbers.
thank you both.
