snowster Posted August 16, 2011 Share Posted August 16, 2011 hi having recently brought my car (mk3 ghia estate 03)the parking sensor alarm is constantly sounding when in reverse is there anything i can check or replace before i take it in to a ford garage to correct this? thanks for your time. Quote Link to comment Share on other sites More sharing options...
cyb Posted August 16, 2011 Share Posted August 16, 2011 sounds like you may have a faulty sensor. Is it possible for you to disconnect one sensor at a time to work out which if any is causing the problem? Quote Link to comment Share on other sites More sharing options...
snowster Posted August 16, 2011 Author Share Posted August 16, 2011 have tried that disconnected each in turn still no change thanks for the advice though Quote Link to comment Share on other sites More sharing options...
mintalkin Posted August 16, 2011 Share Posted August 16, 2011 this may help http://parking-sensor.co.uk/troubleshooting.asp Quote Link to comment Share on other sites More sharing options...
snowster Posted August 16, 2011 Author Share Posted August 16, 2011 this may help http://parking-sensor.co.uk/troubleshooting.asp thanks mate have tried that but still emitting one continuous tone when in reverse Quote Link to comment Share on other sites More sharing options...
cyb Posted August 17, 2011 Share Posted August 17, 2011 have tried that disconnected each in turn still no change thanks for the advice though then I guess the only other advice I can give is... "go forward in life and all your problems will be behind you" :D Quote Link to comment Share on other sites More sharing options...
