chrismar
Mondeo Engine Rattle
hi im looking for some advice i have a 54 plate mondeo tdci 115 bhp, since buying the car few months back it has always sounded like a old escort with a over head valve engine rattling away quite noticeable tappet rattle. now not been totaly none mechanical i know that the engine is twin over head cam with hydraulic rockers so would be pretty hard for them too rattle or am i mistaken, since owning the bottom pully has been changed and a full clutch kit and flywheel has been fitted. couldi be mistaking my rattle as tappet rattle but it be coming from else where on the engine i have noticed a lot of people saying chaning the aux drive belt quitened there engine but would wonder how in that system would give a tapping sound through out the engine any advice greatly apprciated..... as a last note or more fear could it be the timing chain wearing and stretching causeing the rattle....
what you are hearing could be injector knock, the injectors on the tdci can loose there codes and may need recoding or you could try a good injector cleaner treatment in the fuel tank.
hi could you recommend a good injector cleaner ive tried redex and millers diesel eco max too no avail would wynn's hydraulic valve stuff stand a chance and could a good mechanic tell the difference between injector knock and tappet rattle or is there a easy way to spot injector knock...
Hi, I'm not a mechanic but if you shine a torch at the aux belt tensioner and look at the right angle you will see the belt tensile pulley bouncing up and down. Mine does the Sam and has done for over a year. Research says it needs a complete aux belt kit, tensioner, and pulleys. I believe gates do a kit.
