54 Plate Ka - Which Discs?!
4 replies to this topic
#1 johnpsanderson
johnpsanderson
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Name: John
  • Ford Model: Ka
  • Year: 2004
Posted 18 August 2011 - 12:33 PM
Looks like the front discs/pads need changing on my Ka. Trying to work out which size discs i need - but local parts supplier http://www.wilcodire...e=stores#WILN09 seem a bit vague on which discs i need. 54 plate KA is down as 20mm max / 18mm min discs (looks like earlier models had 12mm discs?). EBC lookup http://www.ebcbrakesdirect.com/car/ tells me i need 240mm diameter discs. Local supplier tells me i need to pick between 239.7mm dia (12mm), 239.5mm dia (22mm) or 258.2dia (20mm) discs.
Help!
Have something to contribute?
#2 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,551 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 18 August 2011 - 03:24 PM
this may help
http://www.apecbraki...73&notify=added
#3 johnpsanderson
johnpsanderson
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Name: John
  • Ford Model: Ka
  • Year: 2004
Posted 18 August 2011 - 04:57 PM
Thanks - helpful - but doesn't marry up with any of the options being offered by the supplier..! I may try elsewhere... Assume differences of less than 1mm on diameter are irrelevant?
#4 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,551 posts
  • Name: mintalkin
  • Year: 2006
Posted 18 August 2011 - 07:38 PM
239.5 dia (22mm) usually used by 1.3 engine
258.2 dia (20mm) usually used on 1.6 engine
this could be the confusion at the supplier.
#5 delboy
delboy
  • 545 posts
  • Name: martin
  • Ford Model: c-max ghia 1.8 petrol /ka 1.2 mk2
  • Year: 2004
Posted 18 August 2011 - 09:05 PM
take wheel off and measure across disk cant remember if vented or not
i think they single non vented ones you will know when you take wheel of
if vented they will look like 2 disks together
look here
www.buypatrstby.co.uk
if not sur phone them with your reg & they will give you correct ones
hope this helps
Not what you're looking for?
