Airbag Light
3 replies to this topic
#1 kamifa
kamifa
    Member
  • Budding Enthusiast
  • PipPip
  • 10 posts
  • Name: Kevin
  • Ford Model: Mondeo MK3 2.0Tdci 130
  • Year: 2005
Posted 21 August 2011 - 08:33 PM
Just recently, I have been getting an Airbag light on. The light flashes once and then nine times before coming permanent, i understand from previous comments that this would indicate a fault with the passenger airbag, however I have checked the wiring to the module and this all appears in order and I cannot understand why this should just develope a fault. Does anybody have any ideas?
My car is due for an MOT in October, I believe this is a failure, is this true?
Have something to contribute?
#2 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,558 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 21 August 2011 - 08:56 PM
does the drivers seat get moved for different drivers,if so check and clean the connections under the seat.
#3 smoothdriver108
smoothdriver108
    Member
  • New Member
  • PipPip
  • 28 posts
  • Name: David
  • Ford Model: Escort 16v Zetec 1.6
  • Year: 1996
Have just read on another forum that it will be a tested item from Jan 1st 2012. My Escort had this problem, MOT last May, but it was only an advisory. (Fixed by disconnecting yellow connections , under the driver and passenger seat for 2 minutes with the ignition off, then reconnecting.)
This is from another thread :- "This happened to my \'97 Mondeo. When I asked my local Ford garage about it, the said that this sometimes happens when the contacts get dirty. They suggested disconnecting, cleaning and reconnecting the cable under the driver and/or passenger seats".
#4 kamifa
kamifa
    Member
  • PipPip
  • 10 posts
  • Name: Kevin
  • Year: 2005
Posted 21 August 2011 - 09:03 PM
To be honest, today i have had the seat up on the drivers side as the mechanism that operates the electric raising and lowering of the seat stopped working, so today, i have had a look at the mechanism and there are a couple of teeth broken off the cog inside!!
Not what you're looking for?
