youngy1980 Posted August 23, 2011 Share Posted August 23, 2011 first thing in the morning it will take 10 mins of cranking the engine to start but it doesnt start properly it will idle at 500rpm and you cant rev it,then it will take an extra 5 mins for it to warm up to rev and then every time you start it after that it will do the same thing but it doesnt take as long but when it does sort itself out it drives perfect someone told me that its an injector not working as it should and its putting the diesel back in the tank thanks Quote Link to comment Share on other sites More sharing options...
youngy1980 Posted August 24, 2011 Author Share Posted August 24, 2011 I met someone last night and he said that my diesel pump has had it because when the car is turnt off the pump is ment to keep the injectors full with diesel but it isnt and all the diesel is leaking back into the tank Does sound right Quote Link to comment Share on other sites More sharing options...
