04 Streetka Squeaky (Fan) Belt
8 replies to this topic
#1 DELRIO
DELRIO
    Newbie
  • Pip
  • 8 posts
  • Name: del
  • Ford Model: street ka
  • Year: 2004
Posted 12 September 2011 - 03:58 PM
04 plate StreetKa, 53,000 miles
when i start her up there is a squeaking noise coming from the drivers side of the engine bay, what i think is the fan belt. it goes away after a while once the engine has warmed up.
has anyone else experienced this and could it be related to my over-heating issue???
cheers in advance,
DEL
ps im checking coolant levels when engine is cold before each journey and its always fine.
#2 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 12 September 2011 - 04:03 PM
cheers in advance,
DEL
It could be the belt squeaking becuase its worn or not tight enough. but it may well be related to your overheating problem (haven't yet read any of your other posts) as it may be the water pump thats squeaking..
#3 DELRIO
DELRIO
    Newbie
  • Pip
  • 8 posts
  • Name: del
  • Year: 2004
Posted 12 September 2011 - 05:12 PM
thanks stef do you think i should start by getting a garage to adjust/replace the belt and if so how is there anything I can do to minimise the total cost?
DEL
#4 delboy
delboy
  • 329 posts
  • Name: martin
  • Ford Model: c-max ghia 1.8 petrol
  • Year: 2004
Posted 12 September 2011 - 05:22 PM
sounds like the aux belt not an expensive job for a garage to do
get them to change the tensioner at the same time as doing the belt
the overheating mabe a stuck thermostat about £10.00 part 20 min fix from memory from other cars i have done
#5 SandyCat
SandyCat
  • 62 posts
  • Name: Rick
  • Ford Model: Fiesta Mk7 1.4 Zetec
  • Year: 2009
Posted 17 September 2011 - 11:20 PM
When it's running spray some WD40 onto the belt. If the noise disappears you know it's that belt. Ours does it slightly. Like a swish swish noise until it's warmed up. WD40 minimises it.
#6 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Year: 2006
Posted 17 September 2011 - 11:35 PM
wd40 is not a good thing to be spraying on a rubber belt..and it will reduce the friction between the belt and pulleys. talcom powder would be a better choice.
#7 SandyCat
SandyCat
  • 62 posts
  • Name: Rick
  • Year: 2009
Posted 18 September 2011 - 09:13 AM
The squeaking normally occurrs more on damp cold mornings. The WD40 dries this out which is why the noise stops. The WD40 evaporates almost immediately.
Obviously I am not suggesting a huge dose if it. Just a light spray will do the job and is a well known fix albeit temporarily and good for checking which belt it is.
But it is normally a sign of belt wear and will eventually need replacing or adjusting.
#8 DELRIO
DELRIO
    Newbie
  • Pip
  • 8 posts
  • Name: del
  • Year: 2004
Posted 19 September 2011 - 10:17 PM
thanks for comments all, will get the aux belt replaced and possibly thermostat at same time and report back :D
#9 Chester
Chester
  • 30 posts
  • Name: Chester
  • Ford Model: StreetKa
  • Year: 2004
Posted 17 January 2013 - 10:58 PM
Ah, looks like an old thread that represents pretty much what's happening on the wife's car, that's the rodent vocals rather than getting hot under the collar. Does anyone know if it's a good idea to do any other maintenance at the same time? The only reason I ask is coming from camp VAG (VW Audi Gruppe), it's advisable to change the water pump at the same time as a whole cambelt and tensioner kit with the PD diesel engines. Suffice to say, short term gain here (or just changing the belt itself) leads to long term pain which I'm aiming to avoid. This also avoids a belting in the crown jewels and absence of unspeakable pleasures for the foreseeable!
I jest, but any hopeful hints greatfully received. :)
