Is There A Hidden Usb Port In A Mk4 Mondeo???
16 replies to this topic
#16 Alpha TD
Alpha TD
    Newbie
  • Pip
  • 2 posts
  • Ford Model: Mondeo 1.8 TDCI
Posted 11 February 2013 - 05:00 PM
Hi Quiggles, The lead you found on the left hand side of the glove box is a rouge lead for some other use no one at Ford can figure out. I just sent my USB port back due to the wrong config. You need to do what it states earlier and that is too upgrade your stereo and BT module then you can attach a loom to the plug. I havent done this as i'm gonna look for another way.
#17 Quiggles
Quiggles
    Newbie
  • Members via Twitter
  • Pip
  • 2 posts
  • Ford Model: Mondeo Mk 4 2.0 Tdci Titanium X
Posted 11 February 2013 - 05:06 PM
Probably bad form to reference other forums, and I apologise for that, but I have included the link so the appropriate people are credited...
I did more research myself - the rogue cable appears to be something to do with the passenger airbag but the full story seems to be:-
www.fordmondeo.org/forum/printpost.php?tid/807994/
Behind the glove box you will find the main wiring harness.
On pre 08/2008 Mondeo's (fitted with BT/VT) there was an 8 pin socket and a plug looped wires to control the microphone wiring (6000/Sony or satnav).
On post 08/2008 Mondeo's (BT/VC now fitted as standard) there is a 22 pin socket and plug with looped wires, this varies the AUX socket wirng for BT/VC only (aux direct to stereo) or BT/VC+USB (aux to BT/VC module, stereo output from BT/VC module to stereo).
Therefore AUX socket in glove box has 3 wires.
If you can find a Ford dealer who knows how to upgrade the software on a BT/VC only module (later 19G488 with usb socket), you would only need to get :-
Cable Assembly 1543691 £20.14 Cable from the BVC to the USB Socket
Control AS 1543450 £3.15 USB Socket
Bezel 1540778 £5.55 Plate to mount USB in glove box
Otherwise you will need a 19C112 module as well.
Unfortunately I cannot post any pictures of the above socket, or it's exact position as my Mondeo was a 12/2007 build without BT/VC.
PLEASE NOTE
The date the wiring changed is given as 08/2008 by Ford, but any car built within a month or so of this date should be visualy checked (to confirm wiring)before ordering any parts.
