Mk2.5 Focus 2010 leaking
38 replies to this topic
#31 salsheikh
salsheikh
  • 867 posts
  • Name: Sal
Posted 25 May 2012 - 08:14 AM
someone had a leak from the door mirror housing that let water into the footwells. have a searhc on here for it.
Andy, I would get the hosepipe out and drench the car to see if there are any more leaks.
#32 ChrisH
ChrisH
  • 154 posts
  • Name: Chris
  • Ford Model: Zetec Climate 1.8 TDCi
  • Year: 2006
Posted 26 May 2012 - 08:35 AM
done ive done a atchdog report time for others to join in
How do i join in?
#33 artscot79
artscot79
  • PipPipPipPipPip
  • 5,324 posts
  • Name: arthur
  • Year: 2006
Posted 26 May 2012 - 09:56 AM
go to google type watchdog and youll get the site on the top bar it has my reports click and add
#34 micksilver
micksilver
    Member
  • PipPip
  • 13 posts
  • Name: Mick
  • Ford Model: Focus 1.8 Style
  • Year: 2009
Posted 06 June 2012 - 04:57 PM
Artscot
I cant find your report on the watchdog site? can you post a link?
#35 artscot79
artscot79
  • PipPipPipPipPip
  • 5,324 posts
  • Name: arthur
  • Year: 2006
Posted 06 June 2012 - 05:44 PM
you fill it in on here http://www.bbc.co.uk...hdog/gotastory/
#36 top banana
top banana
  • 104 posts
  • Ford Model: Fiesta Zetec 2011 in Mars Red
Posted 24 September 2012 - 08:20 PM
My car was repaired back in 2010 by main dealer.... every couple of months I check by the VIN view cut out in the carpet by drivers side.
after this heavy rain recently I decided to check, and yup its leaking again. Car now completely out of warranty as its a 2008 model.
Attached are the photos of the wet underlay and the 'repair' the dealership did in 2010 (eek) No evidence of leaking from here though.
Not best pleased today!
Any ideas?
#37 dny2004
dny2004
    Newbie
  • Pip
  • 1 posts
  • Name: Danut
  • Ford Model: Focus Econetic 2008
Posted 25 September 2012 - 07:13 PM
Hello.
I have the same problem with my car (Focus 12.2008 manufactured). Mine is a left hand drive, so I have water leaking on right side passenger side, only when parked uphill. So far i sealed with silicone the air intake from the vent motor, and a little rubber hose entrance under the right side of the windscreen but with no luck. I noticed that the water is coming from a small plastic bolt and a steel reinforcement bar underneath the glove box. Didn't have time to investigate more but I am determined to sort this out before it gets really rainy.
#38 artscot79
artscot79
  • PipPipPipPipPip
  • 5,324 posts
  • Name: arthur
  • Year: 2006
Posted 25 September 2012 - 07:39 PM
there is 3 places each side it can come from if you look through the gap between the door and the wing with the door closed theres 3 rubber grommets along near the doors hinges 1 near the top hinge 1 centre and 1 slightly lower down these can and do leak however getting to them is not easy as theres just not enough of a gap the rain naturally runs between this point and saturates the rubber grommet allowing water in
as for the rain in the glove box remove the scuttle panel and in th ecorners below the windscreen check the seam sealer if in doubt get marine grade silicone from ebay and go over the seams
#39 WJP
WJP
    Newbie
  • Pip
  • 5 posts
  • Name: John
  • Ford Model: Focus Titanium TD 109
Posted 31 January 2013 - 06:37 PM
I've joined the water ingress club, but has been fixed on third attempt! My garage had no previous experience of this bulkhead seal problem. Ford's don't want to know, did anybody get a response from Watchdog?
