Engine Loses Power - 2000 Mondeo Verona 1.8 Petrol
4 replies to this topic
#1 Stewr
Stewr
    Newbie
  • New Member
  • Pip
  • 4 posts
  • Name: Stewart
  • Ford Model: Mondeo Verona 1.8 Zetec
  • Year: 2000
Posted 08 October 2011 - 07:51 AM
Hi guys,
I think that this is down to a broken catalytic converter - the engine revs freely fine but under load it gets to about 2000 revs then acceleration is very very slow, no power and takes an age to get to 60 70mph on the motorway. There is a bit of a whine - like a sucking sound and the exhaust just got slightly louder and rattlier. I think the Cat is knackered and is blocking the exhaust flow but any advice would be appreciated (I am going to replace the HT leads, plugs, oil change etc. anyway) Also should I buy a Ford cat or an aftermarket replacement? and if the latter what is a reliable make or supplier/ (sorry, Im new - am I allowed to ask that?)
thanks
Stew
Have something to contribute?
#2 andthen
andthen
    Member
  • Budding Enthusiast
  • PipPip
  • 21 posts
  • Name: mike
  • Ford Model: mk4 mondeo zetec with sports pack
  • Year: 2009
Posted 08 October 2011 - 08:10 AM
i would put 50p on it being the cat .. my escort did the same years ago and that was down to the cat.. i fitted a aftermarket job and it worked fine , was£150 (inc fitting)at the time ,but that was 2004;-)
#3 fishpond 47
fishpond 47
  • 363 posts
  • Ford Model: mk3 mondeo x2 + a ka
Posted 08 October 2011 - 11:37 AM
You have answered your own question if you are aware the cat has had it, I'd check the back box aswell though, an aftermarkect cat will do the job as good as a ford one.
#4 Stewr
Stewr
    Newbie
  • New Member
  • Pip
  • 4 posts
  • Name: Stewart
  • Year: 2000
Posted 25 October 2011 - 07:43 AM
Just to let you know, I changed the Cat at the weekend and it was knackered and was causing back pressure under load and resulted in no power above about 2000 rpm. New one sourced for £48.00 including delivery, which was cheap and I fitted it OK (after drilling one of the studs out of the exhaust and using a bolt instead!) Serviced the old girl (the car not the wife!) and she runs like a dream again. Now if only I can figure out the water leak!!!
cheers all,
Stew
#5 Stewr
Stewr
    Newbie
  • New Member
  • Pip
  • 4 posts
  • Name: Stewart
  • Year: 2000
Posted 25 October 2011 - 07:44 AM
cheers all,
Stew
Not what you're looking for?
