Windscreen Washers
4 replies to this topic
#1 Graham111
Graham111
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Name: Graham
  • Ford Model: Mondeo
  • Year: 2003
Posted 08 October 2011 - 09:43 AM
Hi ppl I have just bought a 03 mondeo I have a slight problem the windscreen washers at the front are not working but the 1at the back is any ideas
Have something to contribute?
#2 fishpond 47
fishpond 47
  • 363 posts
  • Ford Model: mk3 mondeo x2 + a ka
Posted 08 October 2011 - 11:15 AM
can you hear the pump/motor buzzing/going when you try them? if yes then try clearing the washer nozzels with a pin, if no then it will require a new pump.
changing the washer pump is a fiarly easy job.
#3 Graham111
Graham111
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Name: Graham
  • Year: 2003
Posted 08 October 2011 - 12:02 PM
Hi no there is no noise coming from it I take it front and back are different pumps
#4 fishpond 47
fishpond 47
  • 363 posts
Posted 08 October 2011 - 03:33 PM
NO they both work of one pump, ie it goes one direction to work the front washers and the other direction to work the rear washer, fraid it's a new pump for you then, as said earlier it's not a bad job to do,
by the drivers wheel, you have to remove the plastic wheel arch trim at the front end not completely just enough to get your arm through in order to reach the washer bottle, the washer pump is only pushed into a rubber grommet and should just pull out with a waggle. note there may be a few different connectors for the electric plug on the pump and when removing the water pipes remember which is which, once the new pump is fitted try it before refitting the wheel arch trim.
I've been looking for one on flebay as mine has also packed up.
#5 Lenny
    Retired Moderator
  • 11,103 posts
  • Ford Model: Focus ZetecS
Posted 11 October 2011 - 12:09 AM
You should be able to completly climb in there and remove the pump all the wea size of ya :lol:
Not what you're looking for?
