Ford Focus 06 Heated Screen Drivers Side Failure Real Reason
Started by k992511, Oct 10 2011 11:11 PM
24 replies to this topic
#16
Posted 06 January 2012 - 01:50 PM
hey dude, I did go a bit over the top with my explanation on how to fix it. but that really is a step by step on how to fix it.
I could have just said remove the plastic trims, access the copper foil and rubber block solder on a new bit of longer cable and put it all back together.
I came across a few problems that I managed to overcome, thats why I done it in so much detail.
It really is an easy fix. you can pick up a solder iron from b&q for less than £10, a bit cable, a knife and some tape.
Thanks for reading my guide dude
#17
Posted 06 January 2012 - 06:10 PM
Back from work now, so I can go on a bit more like the grumpy middled aged man that I am.
First, thanks to the guy who made the video in the first place. Despite the "rear" windscreen bit I understood everything you meant. A very nice explanation.
Second, thanks to Dougie for the quick response. Well done mate for fixing yours. The reasons I can't do it myself are;
I might be able to find a mate, or a mate's son who could have a go. I guess even if you fail it's no loss, as it doesn't work anyway (I should add here that I haven't actually checked the foil strip yet, as it's pitch black out there, and I can't afford a house with a drive, let alone a garage. But if it isn't I'll bare my ar*e in Binns window).
I've got a mate at work who's got a 55 plate Fiesta, and he told me his drivers side FSH had packed in. Is this the same problem?
Can you get banned from these forums for saying you hate Ford?
I've had this Focus since it was a year old with 7500 on the clock. I had to have a new clutch last year at 35000 miles. What's that all about?
Plus my daughter's got an 04 Ka she's had for 3 years. Don't get me started on that. Let's just say the raw materials and the build quality aren't the best.
Wow I feel really great now I've got that of my chest.
Think I'll go outside and put a big chip in the screen, and get a new one on the excess. Or maybe Ford could replace it free of charge as it's obviously a design fault.
Once I'mm 100% sure it's the foil strip, I'm gonna take back to the dealer for his "expert" diagnosis, or to Autoglass who put a replacement in 18 months ago to see what they say. I'll play dumb tho.
Ta Ta for now
- I'm over 50, and can't see anything close up
- I've got fingers like jumbo sausages
Ta Ta for now
#18
Posted 06 January 2012 - 07:17 PM
I wouldn't trust their "expert" diagnosis as far as I could chuck them.
I had my car 6 months took it to a " good " ford dealer, They took it in in the morning, I phoned up at 3pm to see how it was getting on, The girl said I will go check etc. So she comes back and says MR Millar the dash has been taken out of the car and we are testing your window so I don't think you will get the car back today. 35mins later I get a call Mr Millar your car is ready to pick up !
2 weeks after that I get a call from the ford team. Mr Millar unfortunately we wont be repairing your car under warranty as you had the window replaced and its not a genuine ford part. So hands up to them they got me on that one ( it was replaced by the previous owner ) I asked the guy how they would check the window etc and he said all they do is check the window is a ford part. If it is then they replace the window most of the time they get auto glass in so make sure it has the ford logo on it !
fortunately I'm an electrician so I know how to fix these kinds of things. If you get someone who is handy with a solder iron then the fix is very easy. If you follow that step by step it really isnt hard, you dont need to do anything more
#19
Posted 07 January 2012 - 01:37 AM
It isn't a genuine Ford part as far as I'm aware (the replacement w/screen).
None of this surprises me about Ford. When I had the clutch replaced the car was out of warranty anyway but I thought I'd ask. The guy at the service desk said "clutches aren't covered by Ford warranty. If want a warranty like that you need to buy a Mercedes or a Saab or something like that!!!!!!"
What devotion to the badge.
#20
Posted 07 January 2012 - 01:46 AM
since your out of warenty you have no chance really.
If you know a young electrician who is interested in cars im sure he could fix it for you folling the guide.
I have fixed a good few up by my way. I do it in their drive or out on the street.
Your clutch, I guess its a wear and tear part so wont be coverd under warenty ? unless it went really quick once you got the car? but the way I see it... a good quality built car should not need a new clutch before 3 years
#21
Posted 17 February 2012 - 02:57 AM
Guess what? My drivers side quiclear is kaput also... (does this mean that LHD versions pack up on their drivers side also?) Thanks to the confidence given in the repair guide, i'll take a look at the ribbon this saturday and report back... I'll tell you what though... I'll bet you a spicy pot noodle that if i can manage to fix it, then the weather will suddenly, and miraculously turn mild!
#22
Posted 19 February 2012 - 09:49 AM
Thanks to Dougies ST (for the heads up) And my mate, (for his soldering skills) Both sides of my heated front screen now work
I thought i'd drop a few piccies onto this thread for the sake of top up info...
Plug to heated screen removed, end stripped, and extention cable in situ
Plug going to the "copper" ribbon removed and being soldered onto an extension piece of cable (so the "ribbon" is long enough to re-route later)
One of the trickier bits of this otherwise pretty simple repair is the soldering on the repair cable to the ribbon...The bonnet getsd in the way when it's open, so we popped the bonnet down, protected it, and soldered the extension to the ribbon (tricky) The cable end was splayed as much as possible to help simulate the width of the ribbon....
Once soldered, heat shrinked, then loomed for good measure, the cable and ribbon is now long enough to re-route under the wiper motor mechanism out of harms way... So with luck, this repair SHOULD be permanent.... Having said that, the ribbon still had to be cable tied right up under the bulkhead to keep it away from that pesky chafing wiper mechanism...Fingers crossed for a long term repair....
Screen working
Screen working
#23
Posted 22 June 2012 - 03:34 PM
Still a *wee* bit confused about this fault and fix.
So, am I right to believe that the fault develops NOT in the ribbon itself, but in the wire which connects to the ribbon? And that the fix is to leave the ribbon intact and simply cut out and replace (via soldering) the wire connecting to the ribbon with a longer one?
Seems strange to me that the fault develops in the wire when the chafing action appears to happen on the ribbon and not the wire (according to the video in the first post, anyway).
I haven't yet taken the wipers etc off to have a look at what the problem with mine is, but I'm assuming its the same issue the rest of you are having, as it's the same symptoms (driver's side windscreen heating failing, passenger's side fine).
Thanks in advance for anybody who can clarify!
#24
Posted 23 June 2012 - 11:49 AM
Anyone? (Above post).
#25
Posted 01 December 2012 - 09:39 AM
my car has just developed this fault and i have removed the covers etc to find the ribbon has ripped but unfortunately it is very close to where the ribbon joins the screen so its hard to get to. can the ribbon be removed from the windscreen? has anyone had any joy out of complaining to ford?
UPDATE: I thought I would chance my arm and call the company that installed my new windscreen in January this year. They are now going to replace the whole screen under warranty! HAPPY DAYS! Excellent customer service!
No soldering for me this time!
