Timing Belt Change
Started by Danzzza, Oct 14 2011 08:01 PM
9 replies to this topic
#1
Posted 14 October 2011 - 08:01 PM
Just wondering if anyone could tell me when the timing belt should be changed on my car. It's a 2006 1.25 style, and I can't seem to find a definate answer anywhere. My local ford dealer has always been closed anytime I've got a spare 5 mins. Any advice appreciated, cheers
#2
Posted 14 October 2011 - 10:39 PM
Extended Period Maintenance
Brake system
Every 2 years - Renew - brake fluid (LTS 12 154 4)
Air conditioning
Every 3 years - Check temperature at the evaporator outlet tube. Check air conditioning lines for damage and leaks (LTS 34 619 1) (TSB 67/2002)
Cooling system
Every 10 years - Drain, flush and refill with purple Super Plus(LTS 24 122 4)
Auxiliary drive belts
Every 125 000 miles/10 years - Renew (LTS 21 567 5)
Visual body & paint check
Every 12 or 24 months depending on vehicle type and build year/registration date. Carry out during operations marked (+) above - see detailed Check Sheet - if applicable (LTS 54 555 1 +)
You can create your own service schedule to see what is required and when here
Brake system
Air conditioning
Cooling system
#3
Posted 15 October 2011 - 03:49 PM
125k!? I was expecting 60ish! Good news I suppose, thanks for the help
#4
Posted 19 October 2011 - 12:27 PM
I could be wrong, but I didn't think a timing belt was classed as an auxiliary drive belt. I thought auxiliary belts = alternator belt and power steering belt. Willing to be challenged on this view!
I asked a Ford dealer specifically about the timing belt and was told it was 100K or ten years - mine is a 2004 Mk6 1.25 Duratech. It pays to err on the side of caution with a timing belt anyway - and I normally do the water pump at the same time (if it's driven by the timing belt).
#5
Posted 22 October 2011 - 08:06 AM
Currently got 64k on the clock, just seems to be creeping up too high for my liking…
#6
Posted 24 October 2011 - 08:51 AM
It's up to you, but think of it this way:
- in age terms, you are around 50% 'used' (ie vehicle is 5 years old)
- in mileage terms, you are 65% used with another 35% to go.
Personally, I'll be waiting until I've passed 9 years or 90K (whichever is the sooner). I don't think any of the Fiesta engines are prone to premature cambelt failure - I've certainly not seen posts on here complaining about it.
#7
Posted 24 October 2011 - 05:09 PM
Suppose when you put it like that. Hoping to change cars within the next few months anyway, my cars worth literally next to nothing as it stands, just didn't want the belt to fail and then be left with a worthless shell
#8
Posted 23 January 2013 - 10:10 AM
I have a Fiesta 54reg 1.4L petrol, Its done 79,000 Miles and ive only recently purchased this. Would you recommend the cambelt gets changed immedietley or does it have a few miles left on it?
#9
Posted 23 January 2013 - 01:02 PM
It would be due next year anyway, do it sooner rather than later.
#10
Posted 24 January 2013 - 11:54 PM
Mine is an 05 plate with 108,000 on the clock. I took it to get the belt changed around 90,000 and they cant get the camshaft bolt undone so i wouldn't leave it as close as i did. Now im just waiting on the belt snapping and my engine being knackered.
