wobbly gearstick!!
3 replies to this topic
#1 holdawayt
holdawayt
  • 35 posts
  • Ford Model: fiesta
Posted 07 January 2009 - 07:54 PM
hi again, new problem with the festa, but hard to explain.
if i go to put the car into 1st gear, the gearstick will go into gear, BUT if i push it over to the left a bit harder (when its in neutral), it will move the whole gearstick over to the left. i can still select all of the gears without crunching but it is over to the left. knock it back over to the right and it'll behave as normal. it's quite drivable but quite odd. any suggestions would be great.
thanks, Tom.
#2 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 08 January 2009 - 04:26 PM
check if all the linkage and bolts are tight under the gear gater.
#3 vinnyvangough
vinnyvangough
  • Super Mod
  • 2,225 posts
  • Name: Steve
  • Ford Model: Ford Escort RS2000 Mk6 & Mk2 Escort
  • Year: 1996
Posted 08 January 2009 - 04:36 PM
As above, something def sounds loose.
#4 holdawayt
holdawayt
  • 35 posts
Posted 12 January 2009 - 10:52 AM
just realised what it was...
when the gearbox was dropped to get the clutch done one of the clips around the selector rod was loosened and not tightened!!
so the whole thing is rotating where the clip should be.
quick tighten of a bolt n everything's sweet!
