Whining Steering On Full Lock
6 replies to this topic
#1 Focus_ST-3
Focus_ST-3
  • New Member
  • 615 posts
  • Ford Model: Mk2
Posted 21 October 2011 - 07:55 PM
Bit of a strange one here. After having a new engine fitted at the local Ford dealer, my steering has started whining as the steering wheel is turned, becoming increasingly louder as it approaches full lock. If anyone has any ideas as to the nature of the problem, it would be much appreciated. The car is a Mk4 Mondeo 2.5T.
Have something to contribute?
#2 CAR PARTS EXPRESS
CAR PARTS EXPRESS
    Authorised Trader
  • New Member
  • 448 posts
  • Ford Model: mondeo
Posted 21 October 2011 - 07:59 PM
check they havn't lost any pas fluid when doing the job or trapped a pas pipe restricting the fluid
#3 Focus_ST-3
Focus_ST-3
  • New Member
  • 615 posts
  • Ford Model: Mk2
Posted 21 October 2011 - 08:12 PM
Thanks for the reply, I was thinking of draining the system and replacing the power steering fluid. Is that an easy job to do myself?
I should also add that the Ford dealer ensured me that this noise was normal which is clearly a load of rubbish as it didn't do it before the new engine was fitted.
#4 Snapper
Snapper
  • New Member
  • 43 posts
  • Ford Model: Mondeo tdci 130 Zetec
Posted 22 October 2011 - 06:43 AM
Take it back to the dealer, clearly it's a problem from the engine instalation and he is responsible in law
#5 SirKit Breaker
SirKit Breaker
    Member
  • New Member
  • PipPip
  • 13 posts
  • Name: Howard
  • Ford Model: Mondeo MK3 2.0L Petrol Titanium
  • Year: 2006
Posted 26 October 2011 - 06:54 PM
Does sound like cavitation, this is caused by air in the system. In normal operation it will make a noise but when you are in the car you shouldnt be able to hear it. However if you push it onto full lock it will get loud as you will hit the mechanical stop on the steering and this will cause pressure to build up and the pressure relief valve will open to let the excess presure out to prevent damage to the system. Your power steering fluid may just be low, check and top up, then turn lock to lock a time or 3 to bleed the air out, noise should disappear.
Cheers..........Howard
#6 Focus_ST-3
Focus_ST-3
  • New Member
  • 615 posts
  • Ford Model: Mk2
Posted 03 November 2011 - 11:50 PM
Thanks for the reply Howard. I have checked the level of fluid and it is fine. When turning the wheel to full lock a few times, should I remove the cap from the resevoir to allow any air in the system to escape?
#7 Focus_ST-3
Focus_ST-3
  • New Member
  • 615 posts
  • Ford Model: Mk2
Posted 22 November 2011 - 06:32 PM
I took my Mondeo to the Ford dealer today. They said that there is a "problem with the steering rack" and a replacement will cost 500 plus 500 labour. Am I being fobbed of?!
The thoughts of anyone with any technical knowledge in this area would be much appreciated.
Not what you're looking for?
