Fiesta Titanium Bluetooth
23 replies to this topic
#16 julieef
julieef
    Member
  • New Member
  • PipPip
  • 14 posts
  • Name: julie
  • Ford Model: fiesta
  • Year: 2011
Posted 23 October 2011 - 07:35 PM
I'm so totally frustrated with it now,going to leave it until tomorrow I've uninstalled kies and will re install tomorrow,thanks soooooooooo much for your help so far,going to have a glass of wine or 2 now
Julie
Have something to contribute?
#17 Preee
Preee
    Ford Fruitcake
  • 4,372 posts
  • Name: Paul
  • Ford Model: Focus Tit X Mk3.5 | Fiesta Zetec Mk7
  • Year: 2015
Posted 23 October 2011 - 07:41 PM
There's no doubt the program sucks , in your user manual look how to get the setting to "Ask on connection" or Samsung Kies on connection. I pm'ed you a link to a Samsung forum , they are good there. and will help you.
But it seems on the most just to be a connection error probably linked to the fack its on original 2.2.1 firmware , there has been several updates since that firmware.
Failing that you could ask where you got it from to update it for you , or if you have another PC try installing on that one.
I think for your 2.2.1 it's
settings/aboutthis phone/usb settings ------ ask on connection or samsung kies
#18 julieef
julieef
    Member
  • New Member
  • PipPip
  • 14 posts
  • Name: julie
  • Year: 2011
Posted 24 October 2011 - 10:03 AM
After a lot of hassle managed to re install kies and update my phone,but guess what still won't work in the car the problem i'm getting now is it starts to dial then i get the ussd running message up but after that i'm getting another message on the phone saying "connection problem or invalid MMI code" I haven't downloaded any apps or anything so don't suppose you have any suggestions on this latest problem.
Thanks again
#19 Preee
Preee
    Ford Fruitcake
  • 4,372 posts
  • Name: Paul
  • Year: 2015
Posted 24 October 2011 - 06:05 PM
hmmmm not easy .
Ok first to try is:
3 button reset.
turn phone off wait for it to vibrate
hold in volume up button , center menu button then press power on.
when you see galaxy s , release power button and continue to hold vol up and menu button.
when you see blue and yellow writing release all buttons.
Use vol down button goto "wipe cache partition" and hit center menu button
then
then use vol down goto "wipe date/factory reset" and press menu button
then vol down to reboot and hit center menu button.
try again.
back up numbers this will factory reset your phone
other things to try if that don't work , remove sim and put in another phone and make a chargeable call , then try again
turn off speed dial
try and activate mobile traker
If none of this works goto that forum i sent you in a Private message and join and ask them on there they may have a better solution.
#20 Preee
Preee
    Ford Fruitcake
  • 4,372 posts
  • Name: Paul
  • Year: 2015
Posted 24 October 2011 - 06:12 PM
Under about phone what is your Firmware now you have updated?
#21 julieef
julieef
    Member
  • New Member
  • PipPip
  • 14 posts
  • Name: julie
  • Year: 2011
Posted 24 October 2011 - 06:40 PM
Hi Thanks again i'll try all that the firmware says 2.3.3
#22 Preee
Preee
    Ford Fruitcake
  • 4,372 posts
  • Name: Paul
  • Year: 2015
Posted 24 October 2011 - 06:48 PM
let me know how you get on ;)
#23 julieef
julieef
    Member
  • New Member
  • PipPip
  • 14 posts
  • Name: julie
  • Year: 2011
Posted 25 October 2011 - 09:59 AM
Hi tried all that still no joy,I have posted the problem on the forum you gave me and an android forum.Its so annoying when you know it should work,don't want to give up on it but not a lot else I can do at the moment. Thanks so much for your help
Julie
#24 Preee
Preee
    Ford Fruitcake
  • 4,372 posts
  • Name: Paul
  • Year: 2015
Posted 25 October 2011 - 06:37 PM
Julie
Sorry i could not solve your problem , at least your on a better Firmware now and it should be a little easier for the Phone tech guys to help , i hope.:)
Not what you're looking for?
