smax official trouble topic
90 replies to this topic
#76 pknottm
pknottm
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Name: Paul
  • Ford Model: s-max
  • Year: 2009
Posted 20 August 2014 - 09:22 PM
I've just had the clutch and DMF replaced in my S-Max 2.0Dti Zetec 59 plate by a local small garage.
Before the replacement, there was no problem selecting any gear (just a grinding when releasing the clutch and vibration at slow speeds).
However, it is now extremely difficult to select first gear. From a standstill I can get it into first gear by putting it into second gear, then immediately into first gear. All others gears are fine.
The garage have said it is due to the gear selector cables being worn and have quoted me £233 to replace.
Does this sound right, or could it be the clutch needs aligning?
Many thanks.
Have something to contribute?
#77 herbertpug
herbertpug
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Ford Model: S-Max 2.5T LPG
Posted 03 September 2014 - 01:38 PM
Hi All.
Have a 2006 - 56 plate 2.5T S-Max. 40,000 miles when bought 2 years ago. Now on 70,000.
Great car. First thing done was convert it to LPG which cost £1,800 and we lost no boot space.
Now gets 27mpg around home (rural) and 32-34 on long trips (200+ motorway miles @ 65-70(ish))
With LPG being 64p/litre locally, double these to get the equivalent cost of Petrol (i.e. 54mpg and 64-68mpg)
280 miles = £30-£35
Issues:
Aircon Failure. Split Hoses and recharge. c. £200.
Steering Rack Failure. Got very heavy intermittently. Sent rack for a refurb (c. £200)+p&p + removal / refitting + Fluids.  - Kelley Bray Steering.
  (Plus washed out the reservoir. All in c. £500. )
Oil Breather Failed. (Noise and air sucked in though dipstick / oil filler cap. Used "peg and sock until repaired"). Ordered Volvo replacement from USA  ($200USD inc post - c. £130) Plus fitting and breather pipe (£20) Plus Labour (c. 3 hours @£55+VAT/h) = £370 or so all in.
Rear Brake and top strip bulbs failed. Simple fix. £5
Brake Handle trim and button popped off and spring ejected. Not fixed yet.
Precautions:
Changed transmission Fluid
Changed PAS and Coolant
Air filter is K&N panel (washable)
At 62k Changed Timing Belt (not a chain!).Plus water pump. Kit c. £110 + garage labour 2-3 hours. (c. £280 all in)
Always used 10w40 fully synth when cheap on HUKD.
Tyre use is OK. Always get camber / toe-in / tracking / alignment checked. especially if curb has been bumped.
Future issues?
Clutch smells a little sometimes on steep, slow hill starts.
Once had alarm going off. Not repeated.
May check boost solenoids.
Car is parked outside normally so expecting alarm module issue :(
#78 klh
klh
    Newbie
  • New Member
  • Pip
  • 1 posts
Posted 20 October 2014 - 01:19 PM
Hello
I have. 2008 smax which has done 90000 miles. When I go faster than 24mph the windscreen wipers go crazy until I slow down below 24 again. The washer fluid won't come through when I push the button but it is full and there are no warning lights.
No trouble with the alarm either. Any ideas appreciated.
#79 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,088 posts
  • Name: James
  • Year: 2007
Posted 20 October 2014 - 01:42 PM
This is more a thread of known issues,I suggest you start a new topic in the smax forum
#80 CraigStam
CraigStam
    Newbie
  • Budding Enthusiast
  • Pip
  • 2 posts
Posted 17 December 2014 - 08:23 PM
I have an S-max T Sport 2.2 Diesel and recently the fuel gauge keeps registering empty or - - whilst driving. Any ideas?
#81 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,088 posts
  • Name: James
  • Year: 2007
Posted 18 December 2014 - 08:18 AM
Ignite just the fuel it could be a fault with the fuel sender unit or wiring to it
#82 CraigStam
CraigStam
    Newbie
  • Pip
  • 2 posts
Posted 18 December 2014 - 08:21 AM
Expensive?
#83 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,088 posts
  • Name: James
  • Year: 2007
Posted 18 December 2014 - 09:14 AM
Depends on where you going. An indie garage should be able to price it up or advise if the job I'd too far out their remit and refer you to an auto electrician
#84 TheNamele55
TheNamele55
    Newbie
  • Pip
  • 4 posts
  • Name: Jonathan
  • Ford Model: S-Max 2.5t
  • Year: 2007
Posted 31 January 2015 - 01:45 PM
I have a problem with my 2.5t S-Max, engine light on with codes - P0075, P0076, P0079 & P0243. I've done extensive research on these codes & just wondering if anyone on here can shed any light on the cause of these problems plz
#85 TheNamele55
TheNamele55
    Newbie
  • Pip
  • 4 posts
  • Name: Jonathan
  • Year: 2007
Posted 31 January 2015 - 04:09 PM
The EML came on after we had the car in for a coolant hose replacing, & came out with them codes & lack of boost. I think they point to some electrical short circuit :(
#86 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,088 posts
  • Name: James
  • Year: 2007
Posted 31 January 2015 - 06:42 PM
Boost is likely they knocked or split a hose I haven't looked at the error codes yet so don't know to what they refer
#87 TheNamele55
TheNamele55
    Newbie
  • Pip
  • 4 posts
  • Name: Jonathan
  • Year: 2007
Posted 31 January 2015 - 07:01 PM
P0075, P0076, P0079, P0243. I've looked what the codes are & possible causes, I think they all point towards a short in the circuit
#88 TheNamele55
TheNamele55
    Newbie
  • Pip
  • 4 posts
  • Name: Jonathan
  • Year: 2007
Posted 31 January 2015 - 10:57 PM
After pondering over the codes & the issues I have with the S-Max, out of curiosity I checked the fuses & found that fuse f11 (valves, MAF control) had blown. Would that be causing these codes?
#89 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,088 posts
  • Name: James
  • Year: 2007
Posted 01 February 2015 - 07:46 AM
That would be causing some chaos yes
#90 smudgesmith
smudgesmith
    Newbie
  • Pip
  • 2 posts
  • Name: edward
  • Ford Model: s-max
Posted 15 February 2015 - 06:31 PM
im having electrical issues, main lights work but full beam, fogs, dash lights and cruse controll doesnt work.
had the issue a few weeks ago but sorted it self now back again
any ideas
thanks
Not what you're looking for?
