Mitsimatt Posted November 3, 2011 Share Posted November 3, 2011 Right I have replaced map,maf and crankshaft sensor and still having problems in the morning I start it loads of mixed smoke black,blue sounds like it ls misfiring have to rev it hard to stop it running like !Removed! the smoke clears driving it around feels like hesitating juddering it dosent do it all the time and feels like the turbo is holding back not giving me all the power as I say it does it most of the time then it runs fine sometime and when it does it goes like !Removed! of the shovel I have no warning lights and when in neutral I rev it and it hits the limiter then do it again it hits the limiter but lower revs about 3,000 rpm it doing my head in only had it for a few weeks and spend a small fortune on it just want it to run normal of once please help thanks Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted November 4, 2011 Share Posted November 4, 2011 hows the service history of the car? small things like filters / oil etc can make a difference, the fact its so erratic tells me it could be struggling to breathe - so try the air filters as well... Mixed smoke, could mean that its got a clogged EGR (if equipped) that may need a clean, otherwise just a pile up of cack inside the fuel system could contribute... Quote Link to comment Share on other sites More sharing options...
Mitsimatt Posted November 4, 2011 Author Share Posted November 4, 2011 Serviced regularly just changed the fuel filter and cleaned the egr valve still the same Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted November 7, 2011 Share Posted November 7, 2011 What about air filter? have you also tried any additives? Quote Link to comment Share on other sites More sharing options...
Mitsimatt Posted November 7, 2011 Author Share Posted November 7, 2011 Air filter is new and got redex is there better stuff for the injectors as redex say fuel system cleaner seen some other stuff with say injector cleaner Quote Link to comment Share on other sites More sharing options...
Barry_ Posted November 7, 2011 Share Posted November 7, 2011 BG244 is supposed to be good. Just stuck some in myself - not notice much difference but then the motor was running ok anyway! Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted November 9, 2011 Share Posted November 9, 2011 Catch rated it quite highly! I havent heard a negative review for it at all! Quote Link to comment Share on other sites More sharing options...
Mitsimatt Posted November 9, 2011 Author Share Posted November 9, 2011 I have just put a can of bg244 in today let's say after 20 miles it's improving more torq and no smoke can't wait to see what it's like after the full treatment Quote Link to comment Share on other sites More sharing options...
Barry_ Posted November 9, 2011 Share Posted November 9, 2011 Thats good to hear. Can't say it made any noticable difference to my motor but sure the previous owner had the injectors changed about 18 mths ago anyway. Mine being the 1.8TDCI with no DPF it still kicks out some smoke when floored but i understand that is normal. I also used Wynns EGR cleaner last weekend and that did make a very noticable difference - obviously the fuel side of my motor is fine but the EGR side was slightly clogged up. I see you cleaned yours already - you take it apart or use something similar?? Quote Link to comment Share on other sites More sharing options...
Mitsimatt Posted November 9, 2011 Author Share Posted November 9, 2011 Na just spayed it in to be honest I'm gonna remove it tomorrow and clean it out properly Quote Link to comment Share on other sites More sharing options...
Barry_ Posted November 9, 2011 Share Posted November 9, 2011 Yer i wanted to take mine off but it seems you need to remove part of exhaust, half the engine plus all the doors, seats and cup holders so decided i couldn't be arsed LOL Made a difference though - might just stick another can through it - Can't do any harm and its only a tenner. Quote Link to comment Share on other sites More sharing options...
Mitsimatt Posted November 9, 2011 Author Share Posted November 9, 2011 8quid at uniparts lol I got all day I'm gonna tackle it wish me luck lol Quote Link to comment Share on other sites More sharing options...
Barry_ Posted November 10, 2011 Share Posted November 10, 2011 Good luck B) Quote Link to comment Share on other sites More sharing options...
