intermittent stalling
4 replies to this topic
#1 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 10 January 2009 - 12:41 AM
hi guys,
A weird attitude from my car tonight on the way home. Was approaching a junction in second gear, had to stop for a car going past, the brake pedal went hard and when i went to turn the steering wheel wouldnt move. when i looked at the dashboard all the usual lights were on for it to be in ignition mode without the engine running. i turned the car off then restarted the engine, started perfect and has never happened again since. any ideas?
When i rev the car and let it return to idle, the revs usually go just below 750 and you can feel a little shake, usually makes the lights flicker then it creeps back up. Never had a cutting out problem with it before though. VSS? ICV?
cheers guys
#2 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 10 January 2009 - 07:38 AM
first to check and clean would be the icv as its the most likely suspect playing up.
#3 SierraYankee99
SierraYankee99
  • 859 posts
  • Ford Model: Ford
Posted 10 January 2009 - 11:45 AM
I agree fella. If that doesnt cure it, could be a remote chance its the VSS starting to fail.
#4 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Year: 2006
Posted 10 January 2009 - 01:46 PM
cheers for that guys, ive had the !Removed! ICV out numerous times in the past to clean it as i thought it was causing my uneven idle but it never made a difference. It has had some amount of crap cleaned out it though. Maybe just need to take it out again for another clean. the car tried to stall again today at a roundabout, just coming to a stop the revs dropped to about 300rpm then climbed back up to normal. Trying to get a hold of one without going to the dealer is something else though.
cheers
#5 chumley
chumley
    Member
  • PipPip
  • 13 posts
  • Ford Model: focus estate 1800i year 2000
Posted 13 January 2009 - 03:36 PM
cheers
saw one on ebay £29.95 cos ithink i have a like problem.....but i bet mine is worse than yours !!
not sure of the quality of these ebays ones though
